HOw Do I count and identify the number of groups in a groups output.
Guest
Oct 03, 2008 Oct 03, 2008
I have a query that reads like this..
SELECT s.spec_Sort,s.spec_ID, s.spec_Name, b.bus_Name, b.bus_ID
FROM (tbl_businesses as b INNER JOIN tbl_SpecBusRel as sb ON b.bus_ID = sb.specbus_busid) INNER JOIN tbl_specialties as s ON sb.specbus_specid = s.spec_ID
ORDER BY s.spec_Sort, b.bus_Name
and then I am outputing like this...
<cfoutput query="rsGetSpecialties" group="spec_Name">
<cfif THIS IS WHAT I NEED)></td><td></cfif>
<h2><a class="specialty" href="javascript;" onclick="dwfaq_ToggleOMaticDisplay(this,'#spec_ID#');return document.MM_returnValue">#spec_Name#</a></h2>
<div id="#spec_ID#" style="display:none">
<cfoutput><p><a href="#request.details#?bus_ID=#bus_ID#">#bus_Name#</a></p></cfoutput>
</div>
</cfoutput>
This displays in this manner...
Specialty
dealer
Specialty
dealer1
dealer2
Etc...
What I am trying to do is find out how many specialties there are, figure out where the middle is so I can insert a new table data cell and start a new column.
Basically - two columns with the data divided in half by specialty NOT by the number of dealers.
I hope that makes sense. Of course I am trying to do it w/ as little query action as possible. My only solution may be to have more than one query and the second only finds a list of the sepcialties that contain the dealers and then find the middle one and simply say if current specialty = middleSpecialty then start a new column.
Thanks all,
Chris
Advanced techniques
759
1) Remove the nested cfoutput tag. It is redundant.
2) The column you use as cfouput's group attribute must also be in the query's order-by clause.
Oct 04, 2008 Oct 04, 2008
To get the number of occurrences of each specialty, do a query of a query
<cfquery dbtype = "query" name = "getNoOfSpecialties">
SELECT spec_Name, count(spec_Name) as noOfOccurrences
FROM rsGetSpecialties
GROUP BY spec_Name
</cfquery>
<cfdump var="#getNoOfSpecialties#">
Guest
Thanks for the replies. I don't need the number of occurances of each specialties - I simply need to know how many specialties there are and then split them in half.
This may be the long way around -but it is what I did...
<cfquery name="rsGetSpecialties" >
SELECT s.spec_Sort,s.spec_ID, s.spec_Name, b.bus_Name, b.bus_ID, b.bus_Pcity, b.bus_PState
</cfquery>
<cfset specs = valuelist(rsGetSpecialties.spec_ID)>
<cfquery name="rsListSpecialties">
SELECT spec_ID,spec_Name
FROM tbl_specialties
WHERE spec_ID in(#specs#)
ORDER BY spec_Name
</cfquery>
<cfset middle = int(rsListSpecialties.recordcount/2)>
<cfset specs = valuelist(rsListSpecialties.spec_Name)>
<cfset middle = listgetat(#specs#,middle)>
then displayed like this...
<td valign="top" width="50%">
<cfoutput><a href="#request.details#?bus_ID=#bus_ID#">#bus_Name# (#bus_PCity#, #bus_PState#)</a><br /></cfoutput>
</div>
*****This is the line that does the splitting *****
<cfif spec_Name EQ middle></td><td valign="top" width="50%"></cfif>
</cfoutput>
</td>
As for removing the extraneous cfoutput --> I thought that I needed that in order to show the material within the grouped data. HOw does CF know what data to repeat and what data to not repeat in a grouped output? I will have to look this one up some more.
thanks for the help
From what you've explained, you don't have to go to all that trouble to find the number of specialties. Since there is a spec_ID, which is apparently unique, you could just do
SELECT count(spec_id) as noOfSpecialties
</cfquery>
You ended with a question about the first cfoutput tag. I wasn't talking about that one. By "nested", I meant the cfoutput tag within the cfoutput tag.
Guest
Oct 05, 2008 Oct 05, 2008
Thanks for the query of the query - I forgot all aobut doing that.
As for the nested output - I too was referring to the nested output.
My understanding is that when you used the 'group=' that you needed to put in the second output wrapper in order to get the unique information output without repeating the duplicate information.
i.e. I thought this ..
<cfoutput group="spec_D">
#spec_Name#
#dealer#<Br>
</cfoutput>
would result in
spec1 dealer1
spec1 dealer2
spec1 dealer3
What I want is
spec1 dealer1
dealer2
dealer3
and that would take this..
#spec_Name#
<cfoutput>#dealer#<Br></cfoutput>
</cfoutput>
Do this and see what happens
#spec_Name#
#dealer#<Br>
</cfoutput>
Guest
Oct 06, 2008 Oct 06, 2008
unfortunately all it does is returne
specname
dealer
specname
dealer
specname
dealer
sadly none of the specials that contain multiple dealers - returns multiple dealers :(
It was fun trying something new
Oct 07, 2008 Oct 07, 2008
OK. Do you now have what you want?
Documentation
