Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Display default value of Dropbox
Avatar
Level 2
I have an adaptive form which I am pre-filling with some data from the currently logged in user. I also have a bunch of drop downs distributed among some child panels of the form. These should show their default value "Please Select" when the form is initialised. In order to do that, I needed to add this value to the prefill.jsp so that the drop downs are pre-filled.
But the drop downs are on child panels which are  dynamically hidden/shown and when I generate a default DoR it 'detects' the value "Please Select" and adds it and the entire child panel to the DoR.
Is there a way to exclude them from the DoR when they are on a hidden panel and also have them show the default text?
Any help is very appreciated. Thanks, Alex
1 Accepted Solution
Avatar
Correct answer by
Level 3
Hi Alex,
This was a bug in 6.1 Feature Pack 1 and it recently got fixed.
Rishi
Avatar
Employee
You can enable the "Exclude fields from DoR If hidden"property at the form level to exclude all the hidden fields from DOR.
Avatar
Correct answer by
Level 3
Hi Alex,
Rishi
Avatar
Level 2
Hi Rishi,
Thanks for the update!
Was this fixed as a hotfix or will this be in 6.2?
Thanks, Alex
Avatar
Level 2
This will be available in 6.2 as well as 6.1 FP1 hotfix.
About default value for drop down, you can use placeholder text to display default text.
Sachin
