Using AEM Forms 6.2 I've created several adaptive forms, each with rules applied to many of the fields. Today I can see the rules but I cannot create a new rule nor can I edit the existing rules. If I select a field that has a rule I can select the Edit Rules icon. Here I see a list of rules that were created. If I select a rule's checkbox, I see the Edit icon. But if I click on the Edit icon it does not do anything. Same for the Create icon. Any ideas?
Solved! Go to Solution.
Total Likes
Hi Mike,
Were any changes made to the system recently, like upgrading or installing service pack?
Nitin
Total Likes
mikep35030180 wrote...
Can you try using the incognito mode and check if the functionality works ? Also, please share your browser console logs seen in 6.2 touch authoring while clicking on the edit icon.
Total Likes
Thanks for your response Rishi. I tried incognito mode - no luck. Here is what my console log is showing when clicking on the Edit icon ...
rulebuilder.js:2738 Uncaught TypeError: Coral.Select.ListOverlay is not a constructor
at Class.render (http://localhost:8080/lc/etc/clientlibs/fd/expeditor/rulebuilder.js:2738:46)
at Class.render (http://localhost:8080/lc/etc/clientlibs/fd/expeditor/rulebuilder.js:4142:38)
at Class.render (http://localhost:8080/lc/etc/clientlibs/fd/af/guideCommonAuthoring.js:6964:32)
at Class.prototype.(anonymous function) [as render] (http://localhost:8080/lc/etc/clientlibs/fd/expeditor/rulebuilder.js:62:26)
at Class.setModel (http://localhost:8080/lc/etc/clientlibs/fd/expeditor/rulebuilder.js:4044:18)
at Class.setModel (http://localhost:8080/lc/etc/clientlibs/fd/expeditor/rulebuilder.js:4498:49)
at Class.setModel (http://localhost:8080/lc/etc/clientlibs/fd/expeditor/rulebuilder.js:4207:37)
at Class.setModel (http://localhost:8080/lc/etc/clientlibs/fd/expeditor/rulebuilder.js:4036:37)
render @ rulebuilder.js:2738
render @ rulebuilder.js:4142
render @ guideCommonAuthoring.js:6964
prototype.(anonymous function) @ rulebuilder.js:62
setModel @ rulebuilder.js:4044
setModel @ rulebuilder.js:4498
setModel @ rulebuilder.js:4207
setModel @ rulebuilder.js:4036
_setRuleBuilderEnabled @ main.js:701
_showRule @ main.js:653
_editRuleButtonClicked @ main.js:521
proxy @ jquery.js:548
dispatch @ jquery.js:4665
elemData.handle @ jquery.js:4333
granite.js:233 GET http://localhost:8080/lc/content/forms/af/Security_Guard_AF/Application-for…79/items/guidetextbox_45... 404 (Not Found)
XMLHttpRequest.send @ granite.js:233
send @ jquery.js:9659
ajax @ jquery.js:9210
ns.persistence.Request.send @ core.js:6701
sendReadParagraph @ core.js:7333
self.readParagraph @ core.js:7211
ns.editableHelper.self.loadConfig @ core.js:25419
(anonymous) @ core.js:29077
loadFromPersistentStorage @ core.js:29071
(anonymous) @ core.js:29183
Total Likes
Hi Mike,
Nitin
Total Likes
Yes Nitin, SP1 for AEM Forms 6.2 was installed. What are your thoughts?
Total Likes
Hi Mike,
Could you please share version of the installed package? Also, was AEM sp1 installed?
Nitin
Total Likes
I installed aem-service-pkg-6.2.SP1.zip.
I have since uninstalled SP1 and everything is working again! As we have no need to install SP1 at this point I consider this issue resolved. Thanks for your input. I owe you.
Total Likes
