Web Service
Oct 06, 2008 Oct 06, 2008
hi,
i am trying to learn how to do a web service.
I used this example to figure this out
http://www.quackit.com/coldfusion/tutorial/coldfusion_web_services.cfm
my code is here
http://www.climatetech.net/cti_webservice/Test_WebService.cfm
Code
<cfinvoke
method="listBooks"
returnvariable="rawXMLFileList"
webservice=" http://www.climatetech.net/WebService.cfc?wsdl">
<cfinvokeargument name="category" value="123">
</cfinvoke>
<cfset FilesXML = XmlParse(rawXMLFileList)>
<cfdump var="#FilesXML#">
and my cfc file is here
http://www.climatetech.net/cti_webservice/WebService.cfc
code
<cfcomponent>
<cffunction name="listBooks"
access="remote"
returntype="string"
output="no">
<cfargument name="category"
type="string"
required="yes">
<cfset Var FileList = "">
<cfset Var getBooks = "">
<cfquery name="getBooks" datasource="DS" maxrows=100 dbtype="ODBC">
SELECT FileToolID,FileTitle, FileDescription, File3
FROM FileTool
Where FileTool.StatusID = 'Approved'
AND FileTool.FileCONFIGID = 24
</cfquery>
<cfsavecontent variable="FileList">
<Files>
<cfoutput query="getBooks">
<File id="#FileToolID#">
<Filetitle>#XMLFormat(FileTitle)#</Filetitle>
<FileLink> http://www.resourcesaver.org/file/toolmanager/#XMLFormat(File3)#</FileLink>
<Description>#XMLFormat(FileDescription)#</Description>
</File>
</cfoutput>
</Files>
</cfsavecontent>
<cfreturn FileList>
</cffunction>
</cfcomponent>
this is really basic but for some reason i can not get this to work. has any one set one of these up and made it work before. i have never done this before but i figure get a basic example working first to understand this.
Advanced techniques
1.3K
In what way does it not work?
sorry when you run this page
i get this error
Could not generate stub objects for web service invocation.
Name: http://www.climatetech.net/WebService.cfc?wsdl. WSDL: http://www.climatetech.net/WebService.cfc?wsdl. org.xml.sax.SAXException: Fatal Error: URI=null Line=30: The string "--" is not permitted within comments. It is recommended that you use a web browser to retrieve and examine the requested WSDL document for correctness. If the requested WSDL document can't be retrieved or it is dynamically generated, it is likely that the target web service has programming errors.
The error occurred in D:\web\customers\CTI\cti_webservice\Test_WebService.cfm: line 6
4 : webservice=" http://www.climatetech.net/WebService.cfc?wsdl">
5 :
6 : <cfinvokeargument name="category" value="123">
7 : </cfinvoke>
8 :
Your first sentence in your OP is "I am trying to learn how to do a webservice." I suggest taking baby steps.
Don't advance to a step until the previous step has been successfully completed.
Step 1.
Write a cfc with one function that accepts no arguments and returns a simple string, like "Hello World".
Step 2.
Invoke it as a cfc
Step 3
Invoke it as a webservice.
Step 4.
Add another function to the cfc that takes a string argument, and returns it.
Step 5.
Invoke it as a cfc
Step 6
You then start building the one you really want. I forget the details, but you might have to refresh your stub objects from time to time.
what is a stub objects? this code used to work like 5 months ago. I never did anything to it and it just stopped working.
I google stub service and found where someone suggest to run something like this
<cfobject type="JAVA"
action="Create"
name="factory"
class="coldfusion.server.ServiceFactory">
<cfset RpcService = factory.XmlRpcService>
<cfset RpcService.refreshWebService(" http://www.climatetech.net/cti_webservice/Test_WebService.cfm")>
but when i do i get this error
Name: http://www.climatetech.net/cti_webservice/WebService.cfc?wsdl. WSDL: http://www.climatetech.net/cti_webservice/WebService.cfc?wsdl. org.xml.sax.SAXException: Fatal Error: URI=null Line=30: The string "--" is not permitted within comments. It is recommended that you use a web browser to retrieve and examine the requested WSDL document for correctness. If the requested WSDL document can't be retrieved or it is dynamically generated, it is likely that the target web service has programming errors.
i built this web service for a not for profit as we are also a not for profit company and so we have a real lack of resources to get out side help so any help i am thankful for big time.
when i try to access
i get this:
Variable Form is undefined.
The error occurred in D:\login\unsecure\Security_Check.cfm: line 3
Called from D:\login\unsecure\RegistrationApplication.cfm: line 1
Called from D:\web\customers\CTI\Application.cfm: line 9
1 :
2 : <!--- Check that form inputs don't have any <script> tags --->
3 : <cfset keys = StructKeyArray(Form)>
4 : <cfif ArrayLen(keys) GT 0>
5 : <cfscript>
is this YOUR ws? did YOU write it? there are obviously errors in it. so
if it is yours - correct those errors (and please, turn off robust
exception info on the production server!). if it is not yours - contact
the company that provides this ws and notify them of the errors.
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
ok so i removed that security code and took away the robust errors. I no longer get an error. So I think that the security srcipts run caused the orginal error. But still the script just runs and runs and then just times out. Is there any place i can find a simple example on how to pull 3 fields out of a database into a web service.
Something like this example
please anyone i really need to get this up and any help on this and i will be so thankful
so here is the error i get now
Name: http://www.climatetech.net/cti_webservice/WebService.cfc?wsdl. WSDL: http://www.climatetech.net/cti_webservice/WebService.cfc?wsdl. org.xml.sax.SAXException: Fatal Error: URI=null Line=31: The string "--" is not permitted within comments. It is recommended that you use a web browser to retrieve and examine the requested WSDL document for correctness. If the requested WSDL document can't be retrieved or it is dynamically generated, it is likely that the target web service has programming errors.
The error occurred in D:\web\customers\CTI\cti_webservice\Test_WebService.cfm: line 8
6 : webservice=" http://www.climatetech.net/cti_webservice/WebService.cfc?wsdl">
7 :
8 : <cfinvokeargument name="category" value="123">
9 : </cfinvoke>
10 :
i saw another thread that says i need to deelte the files in the stubs directory of cfm can anyone tell me is this the case?
ok i think i may have got this work to work finally. maybe this is related to the stub directory? not sure man this is confusing for a newbies on this subject.
did you even look at the error message?
coldfusion.xml.rpc.CFCInvocationException:
[coldfusion.runtime.UndefinedVariableException :
*Variable FileToolID is undefined*.]
your cfc still has errors.
the best way to troubleshoot this, is to make it into a regular cfc, not
a ws, and invoke it directly using <cfinvoke> or createobject(). test it
thoroughly to make sure it works/returns a meaningful error in all
situations before making it into a ws.
Azadi Saryev
Sabai-dee.com
Oct 07, 2008 Oct 07, 2008
Hi Azadi
ya i think i got it working. I do not see any errors anymore and my test works pretty good. I guess if you change stuff you need to delete the files in the stub directory in cfm to make the changes take effect. Its a very strange thing if you ask me.
quote:
Originally posted by: mikey999
Hi Azadi
Not necessarily. You already found the code to refresh your stub objects. You just have to run it once in awhile while you are developing your code.
yes, i hear you. i remember when i was working with ws a lot, that was a
real pain in the &^%... i can't recall now, but i think i have found
some piece of code somewhere that programmatically removed the stubs /
refreshed the ws... i will try to dig it up if i can...
Azadi Saryev
Sabai-dee.com
Dan is right - it looks like you already have that code :)
Azadi Saryev
Sabai-dee.com
Documentation
