I'm trying to compare 4 lists (valuelists) and didn't really
find an efficient way yet.
My lists are p.e.
<4,5,8,6,3,2,7>
<1,2,3,8>
<8,1,2,3>
<3,5,4,9,2,8>
I would like a list with the values which occur in each of
the four lists, like:
<2,3,8>
For the moment I create a query with the first list and then
use SQL (see sample code) to get my result, but this seems very
complicated to me. Is there an easy way in CF?
<cfset categoryIdList = "2,3,8">
<cfquery name="test" dbtype="ODBC">
SELECT
mn_team_ID
FROM
ak_pr_mn
WHERE
mn_cat_ID IN (#categoryIdList#)
GROUP BY
mn_team_ID
HAVING
count(mn_cat_id) = #listlen(categoryIdList)#
</cfquery>
You say your 4 lists are valuelists which suggests that they
are the results of 4 queries. I suggest looking at those 4 queries
and see if there is a way to get your answer by reducing that to
1.
Thank you for your input! I think it's a good way towards a
solution. But as I am a beginner in SQL I have now the following
question:
I have a table called 'ak_pr_mn' with two columns
'mn_team_ID' and 'mn_cat_ID'. At the end I would like to get a list
with mn_team_ID's. Which belong to one or several mn_cat_ID's.
Below my query - I don't get how to write the WHERE statement if
there is more than one mn_cat_ID. And please note that my result
should only show the mn_team_ID's which belong to both (or more)
categories (not adding the results of the categories!).
Yes I found this already out but this doesn't give me the
requested result! I'm sorry I'm not familiar with the terminology
but the result contains values which don't appear in ALL lists. It
returs all values which are found PER list. But I need exclusively
values which appear p.e. in list 1 then in list 2 and then in list
3 as described in the example in the very beginning of this topic.
Is there anyway to adjust the SQL statement - this would be
great!
SELECT
mn_team_ID
FROM
ak_pr_mn
WHERE
GROUP BY
mn_team_ID
HAVING
</cfquery>
