I tried creating a custom function for the rules editor using the doc example, but the side panel didn’t contain the functions:
https://helpx.adobe.com/aem-forms/6-2/rule-editor.html
Do I need to initialize it? There is a some form of hook that is missing here…
Total Likes
You can create a client-lib for your adaptive form and create a custom js file. Once you assign the clientLib to Adaptive Form, all the functions that you define within it should appear in the Rule editor. Please see my screenshots.
Total Likes
A client library has been created respectively but the issue I am having is that the custom function is not appearing on the touch UI rules editor sidebar.
I used the following jsdoc sample:
var area;
//Some codes later
area = function(len) {
return len*len;
but it is not working.
Total Likes
1. Could you move the package to apps/ folder for once and try.
2. Is the client lib added to guideContainer property in AF authoring.
Please try this once. This should work fine.
Total Likes
Total Likes
var area;
//Some codes later
return len*len;
Total Likes
Total Likes
Posting for future reference. I faced same issue but when I hard reload my form editor, function appears. Also, if I change something in custom JS, function will disappear from dropdown. I again hard reload and it will show.
