So, I'm tying to animate using the video timeline, but every time I add an empty frame in between, it deletes all following frames and the drawings are just gone. Is there a way to fix this?
Hi smolzaay,
Does the explanation mentioned in this discussion Photoshop: "insert blank frame" deletes all subsequent frames | Photoshop Family Customer Community helps you getting around this issue?
Akash
Hi smolzaay,
Akash
I have the same problem as original poster, however the link in the "Correct answer" just takes me to https://community.adobe.com/
Does anyone have the link to the correct answer or know the correct answer?
My issue occurs in the attached file. Step I took to create this file:
1. Create File
2. Create Video Timeline
3. Use Timeline Panel settings hamburger menu to change framerate from default to 12.
4. Create Blank Video Layer, and draw each frame
When I go to Layers > Video Layers > Insert Blank frame, a blank frame is created at the play head, but all subsequent frames are deleted of content.
I'm on Photoshop 23.5.1, Mac OS 12.0.1, Macbook Air M1 (2020).
Thank you !
It is getting very frustrating looking for the solution to this problem. I've never encountered this before and now this program is getting usless. The duplicate frame for a video layer only works at a higher frame rate...If I was using that frame rate I would be working at Disney and probaly not subscribing to Adobe. What gives with the useless link provided that doesn't have any info what so ever?
