I am trying to install an update to CS6 Extended, both on my desktop and my laptop. The update fails and I get the error code U44M1P7. I got to the instructions on-line on how to fix this error code. The instructions have me go through about 7 layers of directories until I get to the place where the instructions tell me to rename the file 1.0 to 1.0.old. Did this and the update still fails completely.
Now what do I do?
Sharon Fitch
Sharon which CSs6 Version Perpetual Mac version 13.0.6, Perpetual Windows version version 13.0.1.3 or Subscription version 13.1.2. Can you post your current CS6 menu Help>System Info. Mine looks like this. I believe normally when you get that error you nee to install CS6 installation on top of the currnt CS6 that fails to Update the use CS6 meny Help>Updates and it should then work. The installer can be downloaded here ]Download Adobe Creative Suite 6 applications
Updates don't install | Update failure or U44M errors in Adobe Photoshop CS6
Adobe Photoshop Version: 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00) x64
Operating System: Windows 8 64-bit (actuall using Windows 10 but CS6 doe not report that correctly....)
Version: 6.2
System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 12
Logical processor count: 24
Processor speed: 1995 MHz
Built-in memory: 40886 MB
Free memory: 35080 MB
Memory available to Photoshop: 37093 MB
Memory used by Photoshop: 85 %
Image tile size: 1028K
Image cache levels: 6
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Normal
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: False.
OpenGL Allow Old GPUs: Not Detected.
OpenCL Version: 1.2 CUDA 8.0.0
OpenGL Version: 2.1
Video Rect Texture Size: 16384
OpenGL Memory: 2048 MB
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: Quadro 4000/PCIe/SSE2
Display: 2
Display Bounds: top=0, left=-1360, bottom=768, right=0
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Video Card Number: 1
Video Card: NVIDIA Quadro 4000
Driver Version: 21.21.13.7735
Driver Date: 20170501000000.000000-000
Video Card Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvd3dum,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2um
Video Mode: 1920 x 1080 x 4294967296 colors
Video Card Caption: NVIDIA Quadro 4000
Video Card Memory: 2048 MB
Serial number: 90970090970448917498
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
Temporary file path: C:\Users\JOHNJM~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
F:\, 465.2G, 144.4G free
C:\, 224.2G, 77.3G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
Additional Plug-ins folder: C:\Photoshop64 Plug-Ins\
Installed components:
ACE.dll ACE 2012/06/05-15:16:32 66.507768 66.507768
adbeape.dll Adobe APE 2012/01/25-10:04:55 66.1025012 66.1025012
AdobeLinguistic.dll Adobe Linguisitc Library 6.0.0
AdobeOwl.dll Adobe Owl 2012/09/10-12:31:21 5.0.4 79.517869
AdobePDFL.dll PDFL 2011/12/12-16:12:37 66.419471 66.419471
AdobePIP.dll Adobe Product Improvement Program 7.0.0.1686
AdobeXMP.dll Adobe XMP Core 2012/02/06-14:56:27 66.145661 66.145661
AdobeXMPFiles.dll Adobe XMP Files 2012/02/06-14:56:27 66.145661 66.145661
AdobeXMPScript.dll Adobe XMP Script 2012/02/06-14:56:27 66.145661 66.145661
adobe_caps.dll Adobe CAPS 6,0,29,0
AGM.dll AGM 2012/06/05-15:16:32 66.507768 66.507768
ahclient.dll AdobeHelp Dynamic Link Library 1,7,0,56
aif_core.dll AIF 3.0 62.490293
aif_ocl.dll AIF 3.0 62.490293
aif_ogl.dll AIF 3.0 62.490293
amtlib.dll AMTLib (64 Bit) 6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00) 1.000000
ARE.dll ARE 2012/06/05-15:16:32 66.507768 66.507768
AXE8SharedExpat.dll AXE8SharedExpat 2011/12/16-15:10:49 66.26830 66.26830
AXEDOMCore.dll AXEDOMCore 2011/12/16-15:10:49 66.26830 66.26830
Bib.dll BIB 2012/06/05-15:16:32 66.507768 66.507768
BIBUtils.dll BIBUtils 2012/06/05-15:16:32 66.507768 66.507768
boost_date_time.dll DVA Product 6.0.0
boost_signals.dll DVA Product 6.0.0
boost_system.dll DVA Product 6.0.0
boost_threads.dll DVA Product 6.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.1.0.20577 2.1.0.20577
CoolType.dll CoolType 2012/06/05-15:16:32 66.507768 66.507768
data_flow.dll AIF 3.0 62.490293
dvaaudiodevice.dll DVA Product 6.0.0
dvacore.dll DVA Product 6.0.0
dvamarshal.dll DVA Product 6.0.0
dvamediatypes.dll DVA Product 6.0.0
dvaplayer.dll DVA Product 6.0.0
dvatransport.dll DVA Product 6.0.0
dvaunittesting.dll DVA Product 6.0.0
dynamiclink.dll DVA Product 6.0.0
ExtendScript.dll ExtendScript 2011/12/14-15:08:46 66.490082 66.490082
FileInfo.dll Adobe XMP FileInfo 2012/01/17-15:11:19 66.145433 66.145433
filter_graph.dll AIF 3.0 62.490293
hydra_filters.dll AIF 3.0 62.490293
icucnv40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
icudt40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
image_compiler.dll AIF 3.0 62.490293
image_flow.dll AIF 3.0 62.490293
image_runtime.dll AIF 3.0 62.490293
JP2KLib.dll JP2KLib 2011/12/12-16:12:37 66.236923 66.236923
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 2.1.2.1681
mediacoreif.dll DVA Product 6.0.0
MPS.dll MPS 2012/02/03-10:33:13 66.495174 66.495174
msvcm80.dll Microsoft® Visual Studio® 2005 8.00.50727.9307
msvcm90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcp100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcp80.dll Microsoft® Visual Studio® 2005 8.00.50727.9307
msvcp90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcr100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcr80.dll Microsoft® Visual Studio® 2005 8.00.50727.9307
msvcr90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CS6 CS6
Plugin.dll Adobe Photoshop CS6 CS6
PlugPlug.dll Adobe(R) CSXS PlugPlug Standard Dll (64 bit) 3.0.0.383
PSArt.dll Adobe Photoshop CS6 CS6
PSViews.dll Adobe Photoshop CS6 CS6
SCCore.dll ScCore 2011/12/14-15:08:46 66.490082 66.490082
ScriptUIFlex.dll ScriptUIFlex 2011/12/14-15:08:46 66.490082 66.490082
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 3, 0, 2010, 0406
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 3, 0, 2010, 0406
updaternotifications.dll Adobe Updater Notifications Library 6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 6.0.0.24
WRServices.dll WRServices Friday January 27 2012 13:22:12 Build 0.17112 0.17112
Required plug-ins:
3D Studio 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Accented Edges 13.0
Adaptive Wide Angle 13.0
Angled Strokes 13.0
Average 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Bas Relief 13.0
BMP 13.0
Camera Raw 9.1.1
Camera Raw Filter 9.1.1
Chalk & Charcoal 13.0
Charcoal 13.0
Chrome 13.0
Cineon 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Clouds 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Collada 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Color Halftone 13.0
Colored Pencil 13.0
CompuServe GIF 13.0
Conté Crayon 13.0
Craquelure 13.0
Crop and Straighten Photos 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Crop and Straighten Photos Filter 13.0
Crosshatch 13.0
Crystallize 13.0
Cutout 13.0
Dark Strokes 13.0
De-Interlace 13.0
Dicom 13.0
Difference Clouds 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Diffuse Glow 13.0
Displace 13.0
Dry Brush 13.0
Eazel Acquire 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Embed Watermark 4.0
Entropy 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Extrude 13.0
FastCore Routines 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Fibers 13.0
Film Grain 13.0
Filter Gallery 13.0
Flash 3D 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Fresco 13.0
Glass 13.0
Glowing Edges 13.0
Google Earth 4 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Grain 13.0
Graphic Pen 13.0
Halftone Pattern 13.0
HDRMergeUI 13.0
IFF Format 13.0
Ink Outlines 13.0
JPEG 2000 13.0
Kurtosis 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Lens Blur 13.0
Lens Correction 13.0
Lens Flare 13.0
Liquify 13.0
Matlab Operation 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Maximum 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Mean 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Measurement Core 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Median 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Mezzotint 13.0
Minimum 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
MMXCore Routines 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Mosaic Tiles 13.0
Multiprocessor Support 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Neon Glow 13.0
Note Paper 13.0
NTSC Colors 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Ocean Ripple 13.0
Oil Paint 13.0
OpenEXR 13.0
Paint Daubs 13.0
Palette Knife 13.0
Patchwork 13.0
Paths to Illustrator 13.0
PCX 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Photocopy 13.0
Photoshop 3D Engine 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Picture Package Filter 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Pinch 13.0
Pixar 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Plaster 13.0
Plastic Wrap 13.0
PNG 13.0
Pointillize 13.0
Polar Coordinates 13.0
Portable Bit Map 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Poster Edges 13.0
Radial Blur 13.0
Radiance 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Range 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Read Watermark 4.0
Reticulation 13.0
Ripple 13.0
Rough Pastels 13.0
Save for Web 13.0
ScriptingSupport 13.1.2
Shear 13.0
Skewness 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Smart Blur 13.0
Smudge Stick 13.0
Solarize 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Spatter 13.0
Spherize 13.0
Sponge 13.0
Sprayed Strokes 13.0
Stained Glass 13.0
Stamp 13.0
Standard Deviation 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
STL 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Sumi-e 13.0
Summation 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Targa 13.0
Texturizer 13.0
Tiles 13.0
Torn Edges 13.0
Twirl 13.0
Underpainting 13.0
Vanishing Point 13.0
Variance 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Variations 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Water Paper 13.0
Watercolor 13.0
Wave 13.0
Wavefront|OBJ 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
WIA Support 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
Wind 13.0
Wireless Bitmap 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
ZigZag 13.0
Optional and third party plug-ins:
Alias PIX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Analog Efex Pro 2 2.0.12.12
BackgroundFilter 2.2.21.12
Color Efex Pro 4 4.3.24.12
Contact Sheet II 12.0 (12.0x001)
CUR (Windows Cursor) NO VERSION
D3D/DDS 8, 55, 0109, 1800
Dfine 2 2.2.21.12
ElectricImage 13.0
Face Control II 2.00
Fine Touch 3.25
FineStructuresFilter 2.2.21.12
GREYCstoration NO VERSION
HDR Efex Pro 2 2.2.24.12
HotPixelsFilter 2.2.21.12
HSB/HSL 13.0
ICO Windows Icon/Favicon NO VERSION
Import from FastPictureViewer Codec Pack 3.8.0.96
JPEG XR 1, 1, 0, 0
Lazy Nezumi Pro 17.3.25.1950
Lighting Effects Classic 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Luce NO VERSION
Merge to HDR Efex Pro 2 2.2.24.12
Nik Collection Selective Tool 2.1.28
NormalMapFilter 8.55.0109.1800
Picture Package 12.0 (12.0x001)
Reduce Noise v8 8.2.0.0
ScriptListener 13.0
SGI RGB 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
ShadowsFilter 2.2.21.12
Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12
Sharpener Pro 3: (2) Output Sharpener 3.1.21.12
Silver Efex Pro 2 2.2.24.12
SkinFilter 2.2.21.12
SkyFilter 2.2.21.12
SoftImage 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
StarFilter Pro 3 3.0.5.1
StrongNoiseFilter 2.2.21.12
SuperPNG 2.0
Viveza 2 2.1.21.12
Wavefront RLA 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Web Photo Gallery 12.0 (12.0x001)
Plug-ins that failed to load: NONE
Flash:
PaintersWheel
SVG Layers
Photo Collage Toolkit
Mini Bridge
Kuler
Installed TWAIN devices: NONE
Sir,
The operating system is Windows 7 Professional. I own Photoshop CS6
Extended (not a subscription)
I tried to update from the help menu. Update still fails and I get the same
error code.
I am to the point where I will give up trying to update CS6. I am very
dissppointed with Adobe on this issue. I am evaluating ON1 RAW as a
replacement.
Thank you for your response.
Sharon Fitch.
Yes you stated you get error U44M1P7 Your CS6 install is broken/corrupt. Did you install CS6 on top of the broken install to try to fix this by back leveling CS6 to version 13.0, then use CS6 Help>Updates? Like I advised you to do. User here do not work for Adobe we are user like you. I do not care if you fine something else to use. If you want to fix CS6 follow the advice given.
