I want to buy a 10-bit monitor. (I have a Quadro M2000 for 10-bit output) After some research I get confused. If I place composition panel (or program monitor panel in PPRO) on 10-bit monitor, I will see 10-bit output? (My footage also are 10-bit!) Or I must have a I/O card (like Decklink) and use Mercury Transmit to get 10-bit picture?
Thanks...
I just asked Steve. Yes, the same is true for After Effects. All you need is the I/O box or card.
Kevin
You don't need to use an I/O card to use Mercury Transmit. I use it with my regular GPUs to send an image to one of my normal HD monitors.
That said, I haven't tried it with 10-bit. You might need to contact Adobe support to find out.
Hi Morteza Fathollahi,
Did you ever get an answer to this question? Let me know, I'll try and find out for you.
Kevin
Hi Kevin-Monahan​
Stevehoeg in Premiere Pro forum gave me this answer:
10-Bit output from AE and PPro
Is this also correct for AE?
And another question: I contact to Blackmagic and they said Decklink is GPU-independent. But also told me ask from Adobe to sure PPro and AE need Quadro card beside Decklink for 10-bit output or not. So can I have 10-bit output from GTX+Decklink?
Kevin
Thanks for your help Kevin
My pleasure. Thanks!
Kevin
