I'm working on children's books and trying to get InDesing to behave is driving me crazy.
My printer wants non facing pages (so file-> document setup and unckeck Facing Pages)
but then all my page numbers default to the left only which is setup in my masterpage (dual page)
If I leave facing pages checked it looks terrible because the bleed overlaps each page as in the screenshot below
To summarize my problem:
If I use Facing Pages (which I would prefer for layout) I get good page numbers and bad bleed overlap and no way to export individual pages for printer.
If I uncheck Facing Pages I can export correctly but the document uses Master Page A's left side only so my page numbers don't mirror correctly. I also can't see the way the book will look as I layout my spreads.
Any Advice? My solution so far is to use a 2nd master page for all right-pages and make due without being able to see my spreads.
What I really want is another check box in document setup that says: View as spread [ ] or even under the view menu. Why Adobe? "View-> As Spread"
This would let me choose it as non-facing pages for print/export but visually look like i'm working on a book instead of the goofy single pages or going back and forth from facing to non-facing to see what it looks like, then to export it.
You have to change back to facing pages. The printer means he wants to have single pages, page by page. In the PDF export dialog export as single pages, not as spreads.
If you have whole page images on one page, select the spread, go to the page panel menu and deselct Allow new Spread Order (or similiar as I use German, it might be translated different). And then double click on the right page icon of that spread in that document and move it a little bit to the right until a black line appears and release the mouse. It will seperate the 2 pages of a spread in 2 separate spreads but as it is correctly with facing pages.
Here the settings in the Page Panel Menu:
In the English version it is " Allow Selected Spread to Shuffle"
This is the black line you are talking about?
It allows me to drag it to a new line but still won't let me see my full spreads for design purposes but then print them as separate pages will it?
This is what I get:
I think you have misunderstood your printer. You can work with facing pages and still export a PDF as single pages by choosing Pages, not Spreads, under the General tab.
If you need to export with an interior bleed it is perfectly normal for the bleed to come from the facing page and it would not be necessary to split the pages. For any binding (other than wire-o where the inside edge is trimmed and visible), the pages will be folded and gathered, so the inside bleed will be removed when the signatures are imposed. For folded bindings there would never be a reason to split your pages and manually add a bleed.
Thanks for the clarification. I am not positive the binding method they use and as I will be using multiple printers it may change. The style that we've gotten them back in is booklet (simple spreads printed with two staples to hold the 20 page books together. The other printer I'm prepping for is Amazon's createspace.
Do you have more information on the common binding methods. I'm an amature and would love to know more about the process. I've actually made a few of my own blank page journals with a kettle stitch binding.
As for my "problem", because my pictures are sometimes very different, as shown in my original post, it does pose a problem for 2x reasons.
1- If I use facing pages in InDesign then my left page (12 in the example above) has the bleed from page 13 past the crop marks: here is a blank white page left and sky background page right from PDF export (I think I exported as 2up but even single pages have the same bleed issue)
2 - My other problem is that as I design it, I can't see what the pages will look like when the bleed is cropped off, what is my seam going to look like. In my example below I need to know where the hands and the cart's cord are lining up.
Thanks for the help and advice. Is there still something I'm missing about how files are processed for printing?
That's 'saddle stitched' binding. Unless specified otherwise (for instance if you want very heavy card throughout), that would be the usual way to bind a booklet with only 20 pages.
Set your document as facing pages, set your bleed to every edge apart from the inside, and you have image frames that went into the previous inside bleed, pull those sides back to the page boundary.
The only common binding where you would have to be concerned about the content of the inside bleed would be wire-o because the spine edge is trimmed and visible not folded and hidden:
You don't need to split your crossover images, just place one image across the facing pages.
Read up on imposition. Some printers may request an inside bleed, but it will be removed in the imposition process.
A crossover facing page spread in ID (single image) exported with all bleeds
In AcrobatPro showing facing pages
