Is it possible to select the first (top) path, regardless of its name, with a shortcut or a script?
Note: Not making a selection of the path but select the path it self in the path menu. (So that I can rename it with a shortcut.)
I like to know how.
Selecting the topmost Path in the Paths Panel is not the same as double-clicking its name field, though.
// 2017, use it at your own risk;
#target photoshop
if (app.documents.length > 0) {
var myDocument = app.activeDocument;
if (myDocument.pathItems.length > 0) {
myDocument.pathItems[0].select()
#target photoshop
Is it always to be the same name or do you intend to manually enter the new name?
Always the same name: Path 1
(I rename it with an action.)
Thanks 4 your help!
Then try this:
#target photoshop
myDocument.pathItems[0].name = "Path 1"
