This is so simple, but I haven't been able to find the answer.
When I design a print layout (such as a 64 page booklet) with a bleed, when I save a PDF for web use, the sliver of the bleed is on the facing page in the PDF. I tried changing the bleed to "0", but that didn't work.
How do I save a PDF without the bleed showing on the facing page??
Thank you!!!
Are you exporting your document as PDF?
Then when exporting ensure that the following options are Checked Off.
-Aman
