AWS S3: Download media file get corrupted
Participant ,
Jun 01, 2017 Jun 01, 2017
Hi All,
I am trying to download media file (image or video) from AWS S3 using nodejsaws-sdk module. The file is downloaded but I couldn't open as it looks corrupted. Also noted that file size is not same as source file. Refer below code:
var AWS = require('aws-sdk');
var options = {
accessKeyId: "XXX",
secretAccessKey: "XXX"
var s3 = new AWS.S3(options);
var bucketName = 'test-bucket';
var keyName = 'test.jpg';
var params = {Bucket: bucketName, Key: keyName};
var fsModule = "fs";
var fs = require(fsModule);
// This requires when running this code in panel
AWS.util.stream = require('stream');
var writeStream = fs.createWriteStream('D:/test.jpg');
var readStream = s3.getObject(params).createReadStream();
readStream.pipe(writeStream);
I have added aws-sdk node module in my extension folder.
Note:
(1) I can download and open txt file without any issue
(2) If I run this code outside panel context (run in local nodejs server) it works for all type of files including text and media!!
Premiere Pro version: 9.0.0
Extension Type: Panel
Thanks & Regards,
Meet Tank
SDK
6.5K
Enthusiast , Jun 01, 2017 Jun 01, 2017
meett9325076​ It looks like you're not waiting for the download to complete before attempting to pipe. Check out the documentation. The getObject() function takes a callback as its second parameter, a common approach for asynchronous functions. That callback has the form:
function(err, data) { ... }
Where the data parameter has a Body property, which itself is a ReadableStream (amongst other useful types).
Given that, your code should probably look something more like:
Adobe Employee ,
Not directly applicable, but I'm told several partners have used this guidance to good effect, in their panels.
http://www.hacksparrow.com/using-node-js-to-download-files.html
Engaged ,
Does adding
writeStream.end();
as last line  (23) make a difference?
Enthusiast ,
var awsRequest = s3.getObject(params, function(err, data){
    if (err)
        console.log(err, err.stack);
    else
        data.Body.pipe(writeStream);
Note that this also provides you with access to the AWS Request handle that's generated when you call getObject().
I hope this helps.
