In your information is said:
Quiz questions are not supported when the project is published to Vimeo or YouTube.
If I introduce quizzes into the presenter video editor, which streaming video service supports this feature?
I need a service with private users option.
Thank you, /Jose
No idea about WordPress LMS plug-ins. Give it a try.
The quiz functionality it Flash or HTML based, so it should work on any web server. It doesn't have to be Connect or Prime. The challenge is having something that can track the interactions via SCORM or AICC reporting.
Jose,
If you publish the Presenter out put to an Adobe Connect, Captivate Prime server it will support and track the questions and the user responses. You can also use any LMS and the quiz functionality should be supported.
Alternatively, you can put the output on just about any web server and the quiz will be functional but you may not have any reporting to go with it.
Adobe Connect and Captivate Prime both allow you to have users with unique ID's that can have their interactions tracked.
Jorma
And outside Adobe products? Is there a place to share this videos with streaming play?
With any LMS, do you mean even WordPress LMS plug-ins?
Thank you,
