Hi everyone,
First post and total apprentice in After Effects. I'm working on a Mac OS 10.12.5. AE is the latest version on CC (all updates done) with 8g of RAM. I created a small intro animation in AE and when I view it in full preview or when rendering it there are white diagonal lines appearing. When viewing in Quarter preview it's fine... I was able to establish that the white lines come from 2 background layers. I am using the Saber plug-in. I have tried different Project Settings with the same results. Please let me know if you need any further information to help with this situation. Thank you very much!
Composition Settings
Quarter preview
Full Preview
Background layer (1 of 2) - Both background layers produce the white lines. Once one is solved the other should easily be resolved!
Zoom out
Looks like some compatibility issue with Saber...
Mylenium
Hi Mylenium, Thank you for your reply! Compatibility at what level? AE and the plugin in general or with the project/composition settings?
Most likely a general issue with current versions of AE. Check with VC if there is a newer version of the plug-in.
Mylenium
