Here is a layer from an Illustrator file:
Here is the same layer imported into After Effects:
Notice that the layer's bounding box in AE is not the same as that in Illustrator.
Result? I can no longer accurately snap the anchor point to the edge of the layer using something like the 'Move Anchor Point' script (which apart from anything else should have been added as an AE feature *years* ago). Instead, I now have a gap between the anchor point and the actual edge of the artwork, which means if I now want to make that layer fold downwards (it's the lid of a laptop illustration) it's not rotating from the correct point. I now have to manually fiddle each time I want the anchor point on the edge or corner of a layer. A 2-second operation now complicated into a 10-second operation. These things add up.
Message was edited by: Ian Davies Genius! The forum allows you to paste images into a message but then immediately loses them so you just get 'broken graphic' icons instead.
Also logged as a bug report.
I see I can reproduce this in my system as well. it appears to be related to layers that are applied with stroke. this appears to happen when the stroke is set to 'align to center". when setting it to outside or inside it works fine. thanks for submitting the bug report, I will do the same.
do you have any opacity other than 100% in there or any kind of blending modes? if not, skip this
opacity or blend mode changes to any object in your illustrator file will cause the "create shapes from vector layer" feature to any of the layers to behave in the following manner: your shape layer will have an additional group in the shape hierarchy that will contain paths that constitute your Ai artboard and another merge paths operation. and it's very annoying
it could look like something like this if you work in an HD Preset.
BTW HD preset gives you 2 artboards.. it's actually a good thing:Re: AI (illustrator) layers not showing up in AE (after effects) CC 2014 )
here is the shape hierarchy comparison of Layer 1 that is normal and Layer 2 that has 50% opacity:
as you can see the artboard is here as a group with 3 paths and there is an additional merge path operation to the content of the shape.
What to do?
if this is not the case - can you upload the file? I wan't to examine it. I once had a similar issue after I expanded a pie chart but this does not seem to be the case
I'm not using "create shapes from vector layer" so I'm not sure how much of that applies to me, if any.
My composition looks like this in AE:
There are no shape layers or anything else, just imported artwork layers.
What are the options you selected with importing the Illustrator artwork? Screenshots of just the artwork in AI without showing the layer properties (layers expanded), the appearance, and the details of how the illustration is created and screenshots of just a comp panel are pretty useless for diagnosing a problem.
In your screenshot from AI notice that the bounding box is centered on the stroke. This is normal when the stroke is centered on the path. In AE the bounding box will include the stroke. This is also normal. If you only have one layer in an AI file and you import as a comp retaining layer size then the layer will NOT be the size of the path but it will be the size of the artboard.
If you imported the AI file as a comp retaining layer size try selecting the layer in Illustrator and checking the size in points or pixels, then try selecting the illustrator file in the Project panel and checking the size displayed just to the right of the thumbnail when the asset is selected. If they are not the same plus half the width of any outside stroke centered on the path, then there's something going on in the AI layer that isn't visible in your screenshot but should be obvious if you check everything in the AI file. Start by pressing Ctrl/Cmnd + y and check the outlines.
If you did not have "retain layer size" selected then the layers imported from AI will be the size of the art board. This is normal.
If you can't figure it out post screenshots showing the entire UI with the modified properties of all layers giving you problems selected or post the original AI file and we will try and help you out.
Rick, with respect did you look at my original post? If I had imported the artwork without "retain layer size" selected then you wouldn't even see the bounding box in that second screenshot. I'm experienced enough with After Effects and Illustrator to know the difference.
Anyway, here's a video I made showing that the bug exists with even the simplest Illustrator artwork, taking it from creation in Illustrator through to import into After Effects:
Layer bounding box broken when importing artwork from Illustrator - YouTube
This behaviour has only existed since the most recent AE update. I know that because it basically breaks the import of layered artwork, which I do all the time, and would have noticed if it wasn't working before now!
Nice catch with the stroke alignment. I can confirm this is the same for me too. A real shame the bug had to happen on the default alignment that most people use! Wouldn't have been so bad if it just affected inside alignment, say. Not surprisingly, expanding the object appearance also gives correct bounding box, so there is at least a workaround for now.
you can also try "create shapes from vector layer".
Already tried that. Unfortunately with that method AE fails to take the stroke thickness into account when placing the layer handles, which makes sense as a shape layer but doesn't help with placing handles on the edges of artwork. Thanks anyway.
The bounding box in Illustrator has always been on the path, not on the stroke. That goes back to forever. AE's bounding box has always been on the pixels generated by a vector path so it's always on the outside of the stroke. I did read your first post, I was emphasizing a point about importing as a comp for other readers.
I checked out Roei's example video and tried to reproduce the problem. I can but I discovered an odd thing. Put the stroke on the inside or the outside of the path and everything is fine. Put it in the middle and the bounding box is off but it's off in a weird way. Have snap to pixel turned on and pixel preview and make sure that the artwork is an even number of pixels high and wide and the stroke is an even number and you should get a clean edge because the numbers work out but you don't. In fact you cannot get a 1 pixel wide stroke to line up with the pixel grid perfectly even with the stroke set to the inside or outside of the path. Here's a 1 pixel wide stroke that is anti aliasing to 3 pixels:
A one pixel stroke on a shape layer out of position will only end up 2 pixels wide (normal interpolation) and will perfectly align if moved around to properly line up:
The wider the stroke the bigger the error in the bounding box and in edge interpolation (antialiasing).
A quick work around is to jump back into Illustrator and expand the artwork's stroke from the Object menu. That way you won't have to edit the artwork to keep exactly the same look. It's also a really good idea to make sure that your AI artwork is created with snap to pixel turned on and that all horizontal and vertical shapes (rectangles, squares, lines) are an even number of pixels high and wide. This eliminates fractional position values and antialiased lines when the artwork is in it's hero (resting) position.
Further research on the bug brought up some other interesting things.
One other point, create a stroke in Illustrator that is an even number of pixels wide precisely lined up with the pixel grid you can make it line up vertically but you can't get it to line up vertically so there is where the error starts.
Final point, converting a vector layer to a shape layer will not give you a stroked path, but a filled shape. The shape will be wider than the width of the stroke unless the stroke is horizontal and perfectly lined up with the pixel grid. There is always an error with vertical lines.
There is definitely some funky math going on here.
