Can someone tell me please whereabouts in the menus I go to change the order of photos in LR6 in a Mac?
I have a folder with 6 NEF RAW files and the same 6 photos as exported JPEGs (when I exported them I set the "save to the same folder" checkbox). When I look at the folder in LR it shows the 6 JPEGs in a numerically sequenced block followed by the 6 RAWs. When I was working with LR5 it used to place the JPEGs immediately after the RAWs as pairs rather than all the JPEGs followed by all the RAWs - which I found more useful.
I think this can be set as a preference but I can't find where this is done. If someone could tell me where this setting is to be found and what it's called that would be good.
Chaz
In Library grid view, do View > Sort to change the sort order of thumbnails in grid view and the filmstrip.
And yes, you can also change the sort order in the toolbar at the bottom if it is visible.
Thanks John, so obvious - how did I miss that? Job done and now working as I wanted. Sorted! (sorry)
