This has been happening for a few days now. When I try to refine a mask or a selection no changes are made. I'll brush part of the mask using the refine edge tool and it will act as if it's loading something, but then nothing happens. I'm running Photoshop CC 2017.
15.6" FHD IPS Matte Screen
IntelĀ® Kabylake i7-7700HQ
NVIDIAĀ® GeForceĀ® GTX 1050 Ti [4GB] w/Optimusā¢ Technology
8GB RAM
1TB Hard Drive
Windows 10 64-BIT
I'm updating my graphics card as I type this and I updated Windows as well. I'd really appreciate any help with this. Thank you!
Have you tried resetting all tools and if the does not fix your problem try resetting your Photoshop preferences if it use to work correctly
Thank you for your reply!
I did both of those things and it worked once, but then continued to fail. I made a selection and used the tool after each reset and it worked. Then I deselcted and tried to edit the mask, but the edge tool didn't work again. The old refine edge tool seems to work fine though.
Try resetting the again. It it works again. Something must be corrupting your Preferences. If you have any third party extensions and plugins installed try removing them and reset your preferences and see if your Preferences remain good.
Thank you so much for your help again.
I'm unsure of what you mean when you refer to extensions and plugins. As far as I know, I don't have any. Unless you mean brushes, actions, patterns, gradients, or shapes. I do have those. Are they considered plugins or extensions? I apologize for my ignorance.
Use Photoshop menu Help>system Info copy and paste info here....
Adobe Photoshop Version: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877 x64
Number of Launches: 2
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:14, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2808 MHz
Built-in memory: 8047 MB
Free memory: 2 MB
Memory available to Photoshop: 6873 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Disabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA GeForce GTX 1050 Ti"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="22.21.13.8233"
glgpu[0].GLRectTextureSize=32768
glgpu[0].GLRenderer="GeForce GTX 1050 Ti/PCIe/SSE2"
glgpu[0].GLRendererID=7308
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359bc8bcc04\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359bc8bcc04\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359bc8bcc04\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359bc8bcc04\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359bc8bcc04\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359bc8bcc04\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359bc8bcc04\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359bc8bcc04\nvldumd.dll"
glgpu[0].GLDriverDate="20170517000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="2.1 "
clgpu[0].CLDeviceVersion="2.1 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=3210
clgpu[0].CLName="Intel(R) HD Graphics 630"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="21.20.16.4541"
clgpu[0].CLBandwidth=9.25118e+09
clgpu[0].CLCompute=33.8921
clgpu[1].CLPlatformVersion="1.2"
clgpu[1].CLDeviceVersion="1.2 CUDA"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=4096
clgpu[1].CLName="GeForce GTX 1050 Ti"
clgpu[1].CLVendor="NVIDIA Corporation"
clgpu[1].CLVendorID=4318
clgpu[1].CLDriverVersion="382.33"
clgpu[1].CLBandwidth=6.89512e+10
clgpu[1].CLCompute=1106.59
License Type: Perpetual
Serial number: 91198701560031595861
GUIDBucket:
bucket: undefined
test: undefined
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\brian\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 930.8G, 790.7G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/01/26-01:10:02 79.579975 79.579975
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.579975 79.579975
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/01/26-01:10:02 79.579975 79.579975
ahclient.dll AdobeHelp Dynamic Link Library 2.2.0.1
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7) 1.000000
ARE.dll ARE 2017/01/26-01:10:02 79.579975 79.579975
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/01/26-01:10:02 79.579975 79.579975
BIBUtils.dll BIBUtils 2017/01/26-01:10:02 79.579975 79.579975
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/01/26-01:10:02 79.579975 79.579975
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/12/13-13:10:33 80.1089815 80.1089815
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.11
JP2KLib.dll JP2KLib 2016/05/26-01:08:58 79.262945 79.262945
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.1.0
Plugin.dll Adobe Photoshop CC 2017 18.1.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.1.0
PSViews.dll Adobe Photoshop CC 2017 18.1.0
SCCore.dll ScCore 2016/12/13-13:10:33 80.1089815 80.1089815
SVGRE.dll SVGRE 79.579975 79.579975
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeomĀ© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Accented Edges 18.1.0 - from the file āFilter Galleryā
Adaptive Wide Angle 18.1.0 - from the file āAdaptive Wide Angleā
Angled Strokes 18.1.0 - from the file āFilter Galleryā
Average 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āAverageā
Bas Relief 18.1.0 - from the file āFilter Galleryā
BMP 18.1.0 - from the file āStandard MultiPluginā
Camera Raw 9.9 - from the file āCamera Rawā
Camera Raw Filter 9.9 - from the file āCamera Rawā
Chalk && Charcoal 18.1.0 - from the file āFilter Galleryā
Chrome 18.1.0 - from the file āFilter Galleryā
Cineon 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āCineonā
Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āCloudsā
Collada 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Color Halftone 18.1.0 - from the file āStandard MultiPluginā
Colored Pencil 18.1.0 - from the file āFilter Galleryā
CompuServe GIF 18.1.0 - from the file āStandard MultiPluginā
ContĆ© Crayon 18.1.0 - from the file āFilter Galleryā
Craquelure 18.1.0 - from the file āFilter Galleryā
Crop and Straighten Photos 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āCropPhotosAutoā
Crop and Straighten Photos Filter 18.1.0 - from the file āStandard MultiPluginā
Crosshatch 18.1.0 - from the file āFilter Galleryā
Crystallize 18.1.0 - from the file āStandard MultiPluginā
Cutout 18.1.0 - from the file āFilter Galleryā
Dark Strokes 18.1.0 - from the file āFilter Galleryā
De-Interlace 18.1.0 - from the file āStandard MultiPluginā
Dicom 18.1.0 - from the file āDicomā
Difference Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āCloudsā
Diffuse Glow 18.1.0 - from the file āFilter Galleryā
Displace 18.1.0 - from the file āStandard MultiPluginā
Dry Brush 18.1.0 - from the file āFilter Galleryā
Eazel Acquire 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āEazelAcquireā
Entropy 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Export Color Lookup Tables 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āExport3DLUTā
Extrude 18.1.0 - from the file āStandard MultiPluginā
FastCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āFastCoreā
Fibers 18.1.0 - from the file āStandard MultiPluginā
Film Grain 18.1.0 - from the file āFilter Galleryā
Filter Gallery 18.1.0 - from the file āFilter Galleryā
Flash 3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Fresco 18.1.0 - from the file āFilter Galleryā
Glass 18.1.0 - from the file āFilter Galleryā
Glowing Edges 18.1.0 - from the file āFilter Galleryā
Google Earth 4 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Graphic Pen 18.1.0 - from the file āFilter Galleryā
Halftone Pattern 18.1.0 - from the file āFilter Galleryā
HDRMergeUI 18.1.0 - from the file āHDRMergeUIā
HSB/HSL 18.1.0 - from the file āStandard MultiPluginā
IFF Format 18.1.0 - from the file āStandard MultiPluginā
IGES 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Ink Outlines 18.1.0 - from the file āFilter Galleryā
JPEG 2000 18.1.0 - from the file āJPEG2000ā
Kurtosis 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Lens Blur 18.1.0 - from the file āLens Blurā
Lens Correction 18.1.0 - from the file āLens Correctionā
Lens Flare 18.1.0 - from the file āStandard MultiPluginā
Liquify 18.1.0 - from the file āLiquifyā
Matlab Operation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āChannelPortā
Maximum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Mean 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Measurement Core 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āMeasurementCore.8meā
Median 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Mezzotint 18.1.0 - from the file āStandard MultiPluginā
Minimum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
MMXCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āMMXCoreā
Mosaic Tiles 18.1.0 - from the file āFilter Galleryā
Multiprocessor Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āMultiProcessor Supportā
Neon Glow 18.1.0 - from the file āFilter Galleryā
Note Paper 18.1.0 - from the file āFilter Galleryā
NTSC Colors 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āNTSC Colorsā
Ocean Ripple 18.1.0 - from the file āFilter Galleryā
OpenEXR 18.1.0 - from the file āStandard MultiPluginā
Paint Daubs 18.1.0 - from the file āFilter Galleryā
Palette Knife 18.1.0 - from the file āFilter Galleryā
Patchwork 18.1.0 - from the file āFilter Galleryā
Paths to Illustrator 18.1.0 - from the file āStandard MultiPluginā
PCX 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āPCXā
Photocopy 18.1.0 - from the file āFilter Galleryā
Photoshop 3D Engine 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āPhotoshop3DEngineā
Photoshop Touch 14.0 - from the file āPSDXā
Picture Package Filter 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āChannelPortā
Pinch 18.1.0 - from the file āStandard MultiPluginā
Pixar 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āPixarā
Plaster 18.1.0 - from the file āFilter Galleryā
Plastic Wrap 18.1.0 - from the file āFilter Galleryā
PLY 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
PNG 18.1.0 - from the file āStandard MultiPluginā
Pointillize 18.1.0 - from the file āStandard MultiPluginā
Polar Coordinates 18.1.0 - from the file āStandard MultiPluginā
Portable Bit Map 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āPBMā
Poster Edges 18.1.0 - from the file āFilter Galleryā
PRC 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Radial Blur 18.1.0 - from the file āStandard MultiPluginā
Radiance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āRadianceā
Range 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Render Color Lookup Grid 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āExport3DLUTā
Reticulation 18.1.0 - from the file āFilter Galleryā
Ripple 18.1.0 - from the file āStandard MultiPluginā
Rough Pastels 18.1.0 - from the file āFilter Galleryā
Save for Web 18.1.0 - from the file āSave for Webā
ScriptingSupport 18.1.0 - from the file āScriptingSupportā
Shake Reduction 18.1.0 - from the file āShake Reductionā
Shear 18.1.0 - from the file āStandard MultiPluginā
Skewness 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Smart Blur 18.1.0 - from the file āStandard MultiPluginā
Smudge Stick 18.1.0 - from the file āFilter Galleryā
Solarize 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āSolarizeā
Spaces 18.1.0 - from the file āSpacesā
Spatter 18.1.0 - from the file āFilter Galleryā
Spherize 18.1.0 - from the file āStandard MultiPluginā
Sponge 18.1.0 - from the file āFilter Galleryā
Sprayed Strokes 18.1.0 - from the file āFilter Galleryā
Stained Glass 18.1.0 - from the file āFilter Galleryā
Stamp 18.1.0 - from the file āFilter Galleryā
Standard Deviation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
STL 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Sumi-e 18.1.0 - from the file āFilter Galleryā
Summation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Targa 18.1.0 - from the file āStandard MultiPluginā
Texturizer 18.1.0 - from the file āFilter Galleryā
Tiles 18.1.0 - from the file āStandard MultiPluginā
Torn Edges 18.1.0 - from the file āFilter Galleryā
Twirl 18.1.0 - from the file āStandard MultiPluginā
U3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Underpainting 18.1.0 - from the file āFilter Galleryā
Vanishing Point 18.1.0 - from the file āVanishingPointā
Variance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āstatisticsā
Virtual Reality Modeling Language | VRML 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
Water Paper 18.1.0 - from the file āFilter Galleryā
Watercolor 18.1.0 - from the file āFilter Galleryā
Wave 18.1.0 - from the file āStandard MultiPluginā
Wavefront|OBJ 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āU3Dā
WIA Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āWIASupportā
Wind 18.1.0 - from the file āStandard MultiPluginā
Wireless Bitmap 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file āWBMPā
ZigZag 18.1.0 - from the file āStandard MultiPluginā
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions: NONE
Installed TWAIN devices: NONE
I do not know if the CC 2017.1.1 update will fix the problem you write you have but you are missing that update that fixes some if the Issues in CC 2017.1.0 the version you have. Your configuration look OK to me though I would think the feature should work.
I'm scared to ask, but could it be my computer?
