[Moderator moved from The Lounge to After Effects.]
Basically I moved my auto saved folders in to different folders when I tried to open up my latest project again I had to locate Media which hadn't happened with project I located media then It told me to Locate Rendered files which I hadn't see before but I did locate them when my project loaded all my footage with after effects on which was most of them, they just had coloured bars on I tried rendering but nothing happened I tried opening the Effects, in after effects same coloured bars came up nothing working. I tried moving all my Auto saved files back in the same places as good as I could but still didn't work, Is there anyway to resolve this or did Really mess up here.
Is this an After Effects question or a Premiere question? You posted your question in the non-technical Lounge forum, which is where you can connect with your peers for conversations that don't directly relate to product help and support. Let us know what application you are asking about, and we’ll move your question to the appropriate forum so that you can get the answer you are looking for.
~Barb
P.S. For a list of all available product forums, see https://forums.adobe.com/welcome/
You have a lot of detective work in front of you. You'll need to figure out where everything was BEFORE you started moving folders around.
You've also learned a good lesson in the importance of figuring out how to organize a project before you even start it.
