Since last update (2017.1.1), my Photoshop is giving me that error when I try to use some fonts:
- Selected font failed during last operation
I can fix it uninstalling and installing the font again, but the problem come back after sometime, forcing me to repeat the process.
Already tried to reinstall Photoshop and even reinstalled entire Windows 10.
Any solution?
And which font and its file type?
Fenja
The last two (that I remember), Swiss721 TrueType and Proxima Nova OpenType.
But happened to others.
Every time I update Photoshop this happens to me and all my fonts. Have you found any fix for this?
Not yet.
C:\Users\username\AppData\Roaming\Adobe\Adobe Photoshop CC 2017
Move the CT Font Cache folder to the desktop then PhotoShop should work fine. Once it does you can move that folder to the recycle bin or delete it.
I hope this helps it solved my problem.
Thanks kendrajoyner, that seemed to help, at least so far!
I'm glad this was helpful.
This worked. It solved my issue!
We are getting this issue to. It seems to have started with the Windows 10 1703 update (creators update).
