Scripting code for Open AI file in Illustrator......
Engaged ,
Jun 05, 2017 Jun 05, 2017
Hello Friends,
I am creating a html extension .
In this extension I am browsing a AI file by clicking a button .
Now I have to open browsed AI file in Illustrator.
I have to open AI TEST.ai file in Illustrator.
so I need the js code for that.
Please assist me.
Regards
Kundan
Scripting
6.6K
Community Expert , Jun 05, 2017 Jun 05, 2017
Add open method. Before return value like below:
if(f){
app.open(f);
return f.fsName;
Adobe
There are few way to get local files we can use.
Here is an example using Extendscript's File object:
var csi = new CSInterface();
var es = "(function (){"
  + "var f = File.openDialog('Select ai file...');"
  + "return f.fsName;})();"
csi.evalscript(es, function(cb){
  alert(cb);
However, You can use Native function. Probably, its better way.
var f = window.cep.fs.showOpenDialog(false, false, "select ai file...", "", ["ai"]);
Engaged ,
Hello TenA,
By using above code I am able to browse  AI file.
But it's not opening in Illustrator .
Please assist.
Regards
Kundan
You can add open method in Extendscript part like below:
  + "return f.fsName;"
  + "app.open(f)})();"
  alert(cb);
Engaged ,
Thank you TenA,
It's working but It's only browse the path not opening in illustrator.
After click on button , I am able to browse the AI path but browsed AI file is not opening in Illustrator.
Please assist.
Regards
Kundan
Can you show me your codes?
Engaged ,
Please find the atteched code.
main.js
Illustrator.jsx
index.html
Please find file structure of extension.
Please find the above detail.
Regards
Kundan
Valorous Hero ,
In JSX, where you do the application controlling, you have to write all the pertinent code for things Illustrator does - so you need to have an app.open(file) command to open the returned File from the open dialog.
if(f){
app.open(f);
return f.fsName;
Engaged ,
Thanks for reply.
Yes now it's works.
Regards
Kundan
Oct 31, 2018 Oct 31, 2018
Hi kundan,
I need this script pls send me xxxxxxxxx.
I removed your Email address.
Please note that do not write private info in public. You can use Private Message in this forum.
Engaged ,
Thanks for reply  TenA,
I am trying .
Regards
Kundan
