Hi. I would like to have an option to sign without any aspect, just like an invisible signature (the certificate option has it). How I can do it?
[You can't do it in the free Adobe Acrobat Reader where you posted. Moved by moderator to Document Cloud PDF services, formerly Fill & Sign.]
Hi zfunction,
Would you please elaborate your requirement what exactly you want to do.
The field by default would be visible if you have field already in place on the form. But you can try to hide the signature field after you sign the document using JavaScript https://acrobatusers.com/tutorials/show_hide_fields
If this doesn't help as mentioned above help us with your requirement.
-Tariq Dar
Hi. I just want to sign the document with a certificate, but not showing any aspect. When I refer to "aspect" I mean this:
I don't want this to appear in the document. Just the signature.
It's possible?
Hi zfunction,
You may try customizing digital signatures appearance and see that meets the purpose.
Here is the link :Custom Signature Appearances — Digital Signatures Guide for IT
You may also refer to the following link: Customizing digital signature appearance
Let us know if you have any further questions.
-Shivam
