Hi
I can't get the "Video Playback Control Bar" to appear in Library Mode.
Help would be appreciated,
Regards
John
Hi Akash,
Only this morning did I get this resolved. I had given up, having tried all the suggestions.
I came across many sad stories on the internet regarding incompatibilities with LR and Sierra. I update all my software as soon as updates become available. I was beginning to regret this. However, as I had not been alerted to any update for CC for many months I thought I should check and found that I was several versions behind. This did the trick and I am now able to do basic editing within LR
...Copy link to clipboard
Hi John,
We need some more info to be able to help better.
Which version of Lightroom are you using and are you using a Mac or Windows based computer?
What is the format, source, and size of the video you're trying to preview? Use this article Adobe Lightroom supported video file formats to verify that it is supported in Lightroom.
Akash
Hi Akash,
I am using LR CC on iMac running Sierra 10.12.5 and the videos I am trying to view have been on my Mac for some time are MP4. I have viewed them in the past but as I said I am not able to get the "Video Playback Control Bar" to appear. I assume I have got it switched off somehow but can't find where it is hidden! I have looked in the obvious places - View, Window, Tools etc.
Regards
John
Please check that Quicktime is up to date on your computer?
Also, reset the Lightroom preferences to default..Refer Resetting Preferences in Lightroom CC/6 for instructions.
Do backup your catalog before resetting preferences. Check out How to back up catalogs in Lightroom
~Akash
Hi Akash,
I have tried to do all you suggest but still have the problem.
I backed up the catalog.
I have Quicktime 10.4 which as far as I can see is built in to Sierra, as I can't delete it to do a reinstall. It is however Version 10.4 and was updated 20th May 17.
The instructions provided in the link for resetting preferences (dated May 23rd 2015 do not do as expected in that I can't get the dialog to open using these instructions.
Cheers
John
Did you tried resetting the preferences by manually renaming the files mentioned in the link?
~Akashh
Hi Akash,
I came across many sad stories on the internet regarding incompatibilities with LR and Sierra. I update all my software as soon as updates become available. I was beginning to regret this. However, as I had not been alerted to any update for CC for many months I thought I should check and found that I was several versions behind. This did the trick and I am now able to do basic editing within LR on video files. I'm going to have to keep a regular manual check on Adobe. I am sure I got reminders in the past!
Thank you very much for your interest.
Regards
John
Sent from my iPad
Thanks for the update. I am marking your response as a correct answer to this discussion. Hope it will help others to get around this problem.
~Akash
