I am developing a file importer plugin using SDK 2015 over Premiere Pro CC 2017, and I'm finding problems decompressing some DV frame formats. Using PrPixelFormat_YUYV_422_8u_601, PrPixelFormat_YUYV_422_8u_709, PrPixelFormat_ARGB_4444_8u, PrPixelFormat_PALDV25 or PrPixelFormat_PALDV50 everything works fine. The problems arise when Premiere asks for PrPixelFormat_PALDV100_1080i frames. In this case, the behavior of Premiere is as follows:
Window | Behaviour | Header 3 |
Project window | Scrubbing the source clip and sequences containing the source clip work. When the video is double clicked to be opened on the preview window, the clip becomes a green square (as if the frame was not being decompressed) | |
Preview window | Scrubbing or playing the video just shows a green square | |
Media export | Depending on the output format, video is shown and rendered correctly or not shown at all |
The same code is working perfectly for DV and DV50 frames, so does anyone know what's the difference with DV100? Should I do something different?
Hi Angel, I just emailed you directly to follow up.
