Why do some of my Objects have numerous layers, and what can I do to create one texture for them?
Hi
I've not used your gaming engine, but when I've had a similar issue exporting to Blender I did the following:
Before creating your extrusion either Crop or use Image-Trim to bring the canvas edges right in to the edge of the drawing.
Make your extrusion and export. The texture should now fit.
Dave
Layers or surfaces. 3D Layers can be merged therefore you can have several object in a 3d layer and each object cans have several surfaces.
Before you Edit a texture property you can shift click on several material surfaces in the 3D panel so that your edit adjustment applies to them all.
Dave
Thanks for replying.
I took a drawing of mine, and created a 3D Extrusion. Even after reducing the depth to 0, importing it into my game engine, the drawing I used to create the extrusion does not fully fit the mesh and is very off.
Hi
Dave
Ahh!!! Thank you.
