15 Replies Latest reply on Jun 7, 2017 4:19 AM by Соль
    Liquify crushing after 2nd use
    Соль Level 1
      Hello!
      I have a problem, and non of advices didn't help me.
      The liquify filter in PS CC 2017 crushing after 2nd use I already change the video card for more good.
      It was iNvidia GeForce (Gigabyte) GTX 760 and now it is iNvidia GeForce (Gigabyte) GTX 1050 ti
      I don't need the latest versions if PS CC cuz I need the new functional in 2017.
      The strange thing is - then i just setup PS all functional in liquify filter is working, but if try to use it again - the proramm crushing...
        • 1. Re: Liquify crushing after 2nd use
          c.pfaffenbichler Level 9
          Does turning off »Use Graphics Processor« in the Performance Preferences (Photoshop > Preferences > Performance > Graphic Processor Settings) and restarting Photoshop have any bearing on the issue?
          What have you done for trouble-shooting so far?
          Restoring Preferences after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved might be a good starting point:
          https://helpx.adobe.com/photoshop/kb/basic-trouble-shooting-steps.html
          • 2. Re: Liquify crushing after 2nd use
            Соль Level 1
            I turned off this »Use Graphics Processor« and liquify was working but not the "face" functional. I read a lot of variations of solvation of this problem, and all of them tell it's all becouse of video card, but I set new one, much better, and if the PS's full functional doesn't want to work with normal cards and want just "top" it is very bad thing.
            Restarting doesn't help too. Just if reinstall all CC it will work just 1 time and then crushing again.
            I changed the cashe level, and change drawing settings to basic.
            I actually bought new video card! And nothing...  All this functional working on the laptop with geforce 920 mx but not on the pc with 1050 ti.. I belive it's strange..
            Could the problem be in anything else?
            • 3. Re: Liquify crushing after 2nd use
              Neither card seems to be on the list of tested ones
              Photoshop graphics processor (GPU) card FAQ
              so it seems likely the issue is indeed connected to those.
              • 4. Re: Liquify crushing after 2nd use
                Соль Level 1
                • nVidia GeForce: 400, 500, 600, 700 series
                --- I had the 700 (gtx 760)series and had same situation! PS crushed after opening lyquiy filter.
                • 5. Re: Liquify crushing after 2nd use
                  nVidia GeForce GTX 965M & 980M
                  • 7. Re: Liquify crushing after 2nd use
                    Only two nVidia GeForce GTX cards appear to be listed.
                    • 8. Re: Liquify crushing after 2nd use
                      Соль Level 1
                      So your "very open" answer saying what if adobe didn't tests something and it's works (like my laptop 920mx) it's an accidental coincidence and if none of others card don't working it's will be tested later or never.
                      I don't want to thank any of you, guys. You just copy and paste things and don't trying to understand the problem. ALL was working at the 1st time. It's mean what my card CAN run with that functional, but PS crushing after 2d.
                      Moderators, please close this topic, cuz I don't belive here will be any working advice, just copy and paste.
                      • 9. Re: Liquify crushing after 2nd use
                        Just to clarify: I am not an Adobe employee but a Photoshop user.
                        Have you updated the GPU driver yet?
                        I tried pointing out that you seem to have misunderstood the list and referenced a different class of GeForce cards.
                        In any case Adobe has tested Photoshop with several GPU cards, if one uses others then there is no guarantee Photoshop can utilise their resources successfully.
                        You may want to start a new thread, maybe someone else will be able to help you better.
                        • 10. Re: Liquify crushing after 2nd use
                          davescm Adobe Community Professional
                          Hi
                          This is predominantly  a user to user forum (although occasionally Adobe staff do join , you will see them clearly with the red Staff badge).
                          Can you post your full system info (from Photoshop menu Help - System info - Copy) . This may allow someone to spot a problem and try to help you.
                          Dave
                          • 11. Re: Liquify crushing after 2nd use
                            Соль Level 1
                            Версия Adobe Photoshop: 2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006 ( x64)
                            Количество запусков: 0
                            Версия: 7 SP1
                            Архитектура системы: cемейство процессоров Intel: 6, модель: 12, пошаговая обработка: 3 с MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
                            Счетчик физического процессора: 4
                            Частота процессора: 3400 МГц
                            Встроенная память: 8061 МБ
                            Свободная память: 2 МБ
                            Память, доступная для программы Photoshop: 6961 МБ
                            Память, используемая программой Photoshop: 70 %
                            Слои-псевдонимы: ^0
                            Палитра модификатора: Отключено.
                            Многотональная 3D-печать: Отключено.
                            Highbeam: Включен.
                            Размер фрагмента изображения: 1024 Кб
                            Уровней кэш-памяти изображений: 4
                            Просмотр шрифта: Средний
                            TextComposer: Латиница
                            Экран: 1
                            Область отображения: сверху= 0, слева= 0, снизу= 1080, справа= 1920
                            Экран: 2
                            Область отображения: сверху= 192, слева= -1920, снизу= 1272, справа= 0
                            Экран: 3
                            Область отображения: сверху= 1080, слева= 0, снизу= 2160, справа= 1920
                            Отрисовка OpenGL: Включен.
                            Поддержка старых графических процессоров OpenGL: Не обнаружено.
                            Режим отрисовки OpenGL: Расширенный
                            Обычный режим OpenGL: Верно.
                            Расширенный режим OpenGL: Верно.
                            AIFCoreInitialized=1
                            AIFOGLInitialized=1
                            OGLContextCreated=1
                            NumGLGPUs=2
                            NumCLGPUs=2
                            NumNativeGPUs=0
                            glgpu[0].GLVersion="4.1"
                            glgpu[0].IsIntegratedGLGPU=0
                            glgpu[0].GLMemoryMB=2048
                            glgpu[0].GLName="NVIDIA GeForce GTX 1050"
                            glgpu[0].GLVendor="NVIDIA Corporation"
                            glgpu[0].GLVendorID=4318
                            glgpu[0].GLDriverVersion="21.21.13.7595"
                            glgpu[0].GLRectTextureSize=32768
                            glgpu[0].GLRenderer="GeForce GTX 1050/PCIe/SSE2"
                            glgpu[0].GLRendererID=7297
                            glgpu[0].HasGLNPOTSupport=1
                            glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                            glgpu[0].GLDriverDate="20161116000000.000000-000"
                            glgpu[0].CanCompileProgramGLSL=1
                            glgpu[0].GLFrameBufferOK=1
                            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                            clgpu[0].CLPlatformVersion="1.2 "
                            clgpu[0].CLDeviceVersion="1.2 "
                            clgpu[0].IsIntegratedCLGPU=1
                            clgpu[0].CLMemoryMB=1297
                            clgpu[0].CLName="Intel(R) HD Graphics 4600"
                            clgpu[0].CLVendor="Intel(R) Corporation"
                            clgpu[0].CLVendorID=32902
                            clgpu[0].CLDriverVersion="10.18.10.3540"
                            clgpu[0].CLBandwidth=1.61628e+10
                            clgpu[0].CLCompute=112.935
                            glgpu[1].GLVersion="4.1"
                            glgpu[1].IsIntegratedGLGPU=1
                            glgpu[1].GLMemoryMB=2112
                            glgpu[1].GLName="Intel(R) HD Graphics 4600"
                            glgpu[1].GLVendor="NVIDIA Corporation"
                            glgpu[1].GLVendorID=32902
                            glgpu[1].GLDriverVersion="10.18.10.3540"
                            glgpu[1].GLRectTextureSize=32768
                            glgpu[1].GLRenderer="GeForce GTX 1050/PCIe/SSE2"
                            glgpu[1].GLRendererID=1042
                            glgpu[1].HasGLNPOTSupport=1
                            glgpu[1].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,i gd10iumd32"
                            glgpu[1].GLDriverDate="20140330000000.000000-000"
                            glgpu[1].CanCompileProgramGLSL=1
                            glgpu[1].GLFrameBufferOK=1
                            glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                            glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                            glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                            glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                            glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                            glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                            glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                            glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                            glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                            glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                            glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                            glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                            glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                            glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                            glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                            glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                            glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                            glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                            glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                            glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                            glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                            clgpu[1].CLPlatformVersion="1.2"
                            clgpu[1].CLDeviceVersion="1.2 CUDA"
                            clgpu[1].IsIntegratedCLGPU=0
                            clgpu[1].CLMemoryMB=2048
                            clgpu[1].CLName="GeForce GTX 1050"
                            clgpu[1].CLVendor="NVIDIA Corporation"
                            clgpu[1].CLVendorID=4318
                            clgpu[1].CLDriverVersion="375.95"
                            clgpu[1].CLBandwidth=8.91661e+10
                            clgpu[1].CLCompute=769.247
                            Тип лицензии: Подписка
                            Серийный номер: 90970964379604619012
                            GUIDBucket:
                              bucket: 129
                              test: ReduceUXFriction
                            Программная папка: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
                            Путь для временных файлов: C:\Users\Ki\AppData\Local\Temp\
                            Асинхронный ввод/вывод рабочей памяти Photoshop включен
                            Рабочие диски:
                                Загрузочный, 931,3Г, 461,3Г пусто
                            Папка обязательных подключаемых модулей: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\
                            Папка основных внешних модулей: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
                            Установленные компоненты:
                               A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                               ACE.dll   ACE 2016/09/17-17:22:04   79.577309   79.577309
                               AdbePM.dll   PatchMatch 2016/05/17:03:10:18   1.573920   1.573920
                               AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                               AdobeOwl.dll   Adobe Owl   5.2.11
                               AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                               AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                               AdobeSVGAGM.dll   AdobeSVGAGM   79.577309   79.577309
                               AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                               AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                               AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                               adobe_caps.dll   Adobe CAPS   10,0,0,6
                               AGM.dll   AGM 2016/09/17-17:22:04   79.577309   79.577309
                               ahclient.dll    AdobeHelp Dynamic Link Library   2.0.0.2
                               AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                               amtlib.dll   AMTLib (64 Bit)   10.0.0.47 BuildVersion: 10.0; BuildDate: Thu Sep 1 2016 5:16:17)   1.000000
                               ARE.dll   ARE 2016/09/17-17:22:04   79.577309   79.577309
                               AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                               AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                               Bib.dll   BIB 2016/09/17-17:22:04   79.577309   79.577309
                               BIBUtils.dll   BIBUtils 2016/09/17-17:22:04   79.577309   79.577309
                               boost_date_time.dll   photoshopdva   10.0.0
                               boost_signals.dll   photoshopdva   10.0.0
                               boost_system.dll   photoshopdva   10.0.0
                               boost_threads.dll   photoshopdva   10.0.0
                               cg.dll   NVIDIA Cg Runtime   3.0.00007
                               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                               CIT.dll   Adobe CIT   2.1.0.1   2.1.0.1
                               CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                               CoolType.dll   CoolType 2016/09/17-17:22:04   79.577309   79.577309
                               dnssd.dll   Bonjour   3,0,0,2
                               dvaaudiodevice.dll   photoshopdva   10.0.0
                               dvacore.dll   photoshopdva   10.0.0
                               dvamarshal.dll   photoshopdva   10.0.0
                               dvamediatypes.dll   photoshopdva   10.0.0
                               dvametadata.dll   photoshopdva   10.0.0
                               dvametadataapi.dll   photoshopdva   10.0.0
                               dvametadataui.dll   photoshopdva   10.0.0
                               dvaplayer.dll   photoshopdva   10.0.0
                               dvatransport.dll   photoshopdva   10.0.0
                               dvaui.dll   photoshopdva   10.0.0
                               dvaunittesting.dll   photoshopdva   10.0.0
                               dynamiclink.dll   photoshopdva   10.0.0
                               ExtendScript.dll   ExtendScript 2016/01/26-16:09:33   80.1060872   80.1060872
                               icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                               icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                               icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                               igestep30.dll   IGES Reader   9.3.0.113
                               imslib.dll   IMSLib DLL   10.0.0.1
                               JP2KLib.dll   JP2KLib 2016/05/26-01:08:58   79.262945   79.262945
                               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                               libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                               libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                               LogSession.dll   LogSession   7.4.1.60.45263
                               mediacoreif.dll   photoshopdva   10.0.0
                               MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                               pdfsettings.dll   Adobe PDFSettings   1.04
                               Photoshop.dll   Adobe Photoshop CC 2017   18.0.0
                               Plugin.dll   Adobe Photoshop CC 2017   18.0.0
                               PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                               PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                               PSArt.dll   Adobe Photoshop CC 2017   18.0.0
                               PSViews.dll   Adobe Photoshop CC 2017   18.0.0
                               SCCore.dll   ScCore 2016/01/26-16:09:33   80.1060872   80.1060872
                               SVGRE.dll   SVGRE   79.577309   79.577309
                               svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                               tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                               TfFontMgr.dll   FontMgr   9.3.0.113
                               TfKernel.dll   Kernel   9.3.0.113
                               TFKGEOM.dll   Kernel Geom   9.3.0.113
                               TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                               updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                               VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                               VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                               WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                               wu3d.dll   U3D Writer   9.3.0.113
                            Обязательные подключаемые модули:
                               "Умное" размытие 18.0.0 - из файла “Standard MultiPlugin”
                               3D Studio 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               3D-модуль Photoshop 18.0.0 (2017.0.0 x001 x003) - из файла “Photoshop3DEngine”
                               BMP 18.0.0 - из файла “Standard MultiPlugin”
                               Camera Raw 9.10.1 - из файла “Camera Raw”
                               Cineon 18.0.0 (2017.0.0 x001 x003) - из файла “Cineon”
                               Collada 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               CompuServe GIF 18.0.0 - из файла “Standard MultiPlugin”
                               Dicom 18.0.0 - из файла “Dicom”
                               Eazel Acquire 18.0.0 (2017.0.0 x001 x003) - из файла “EazelAcquire”
                               Flash 3D 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               Google Earth 4 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               HDRMergeUI 18.0.0 - из файла “HDRMergeUI”
                               HSB/HSL 18.0.0 - из файла “Standard MultiPlugin”
                               IFF формат 18.0.0 - из файла “Standard MultiPlugin”
                               IGES 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               JPEG 2000 18.0.0 - из файла “JPEG2000”
                               Matlab Operation 18.0.0 (2017.0.0 x001 x003) - из файла “ChannelPort”
                               Measurement Core 18.0.0 (2017.0.0 x001 x003) - из файла “MeasurementCore.8me”
                               OpenEXR 18.0.0 - из файла “Standard MultiPlugin”
                               PCX 18.0.0 (2017.0.0 x001 x003) - из файла “PCX”
                               Photoshop Touch 14.0 - из файла “PSDX”
                               Pixar 18.0.0 (2017.0.0 x001 x003) - из файла “Pixar”
                               PLY 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               PNG 18.0.0 - из файла “Standard MultiPlugin”
                               Portable Bit Map 18.0.0 (2017.0.0 x001 x003) - из файла “PBM”
                               PRC 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               ScriptingSupport 18.0.0 - из файла “ScriptingSupport”
                               Spaces 18.0.0 - из файла “Spaces”
                               STL 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               Targa 18.0.0 - из файла “Standard MultiPlugin”
                               U3D 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               Wavefront|OBJ 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                               Wireless Bitmap 18.0.0 (2017.0.0 x001 x003) - из файла “WBMP”
                               Адаптивный широкий угол 18.0.0 - из файла “Adaptive Wide Angle”
                               Акварель 18.0.0 - из файла “Filter Gallery”
                               Акцент на краях 18.0.0 - из файла “Filter Gallery”
                               Аппликация 18.0.0 - из файла “Filter Gallery”
                               Ассиметрия 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Аэрограф 18.0.0 - из файла “Filter Gallery”
                               Блик 18.0.0 - из файла “Standard MultiPlugin”
                               Ветер 18.0.0 - из файла “Standard MultiPlugin”
                               Витраж 18.0.0 - из файла “Filter Gallery”
                               Волна 18.0.0 - из файла “Standard MultiPlugin”
                               Волокна 18.0.0 - из файла “Standard MultiPlugin”
                               Волшебный карандаш 18.0.0 - из файла “Filter Gallery”
                               Галерея фильтров 18.0.0 - из файла “Filter Gallery”
                               Гипс 18.0.0 - из файла “Filter Gallery”
                               Губка 18.0.0 - из файла “Filter Gallery”
                               Диапазон 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Дисторсия 18.0.0 - из файла “Standard MultiPlugin”
                               Зернистость фотопленки 18.0.0 - из файла “Filter Gallery”
                               Зерно 18.0.0 - из файла “Filter Gallery”
                               Зигзаг 18.0.0 - из файла “Standard MultiPlugin”
                               Излучение 18.0.0 (2017.0.0 x001 x003) - из файла “Radiance”
                               Искривление 18.0.0 - из файла “Standard MultiPlugin”
                               Исправление перспективы 18.0.0 - из файла “VanishingPoint”
                               Кадрировать и выпрямить фотографию 18.0.0 (2017.0.0 x001 x003) - из файла “CropPhotosAuto”
                               Контуры в Illustrator 18.0.0 - из файла “Standard MultiPlugin”
                               Коррекция дисторсии 18.0.0 - из файла “Lens Correction”
                               Кракелюры 18.0.0 - из файла “Filter Gallery”
                               Кристаллизация 18.0.0 - из файла “Standard MultiPlugin”
                               Ксерокопия 18.0.0 - из файла “Filter Gallery”
                               Линогравюра 18.0.0 - из файла “Filter Gallery”
                               Максимальное 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Масляная живопись 18.0.0 - из файла “Filter Gallery”
                               Медиана 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Мел и уголь 18.0.0 - из файла “Filter Gallery”
                               Меццо-тинто 18.0.0 - из файла “Standard MultiPlugin”
                               Минимальное 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Мозаичные фрагменты 18.0.0 - из файла “Filter Gallery”
                               Мокрая бумага 18.0.0 - из файла “Filter Gallery”
                               Наклонные штрихи 18.0.0 - из файла “Filter Gallery”
                               Неоновый свет 18.0.0 - из файла “Filter Gallery”
                               Несовпадения 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Обводка 18.0.0 - из файла “Filter Gallery”
                               Облака 18.0.0 (2017.0.0 x001 x003) - из файла “Clouds”
                               Облака с наложением 18.0.0 (2017.0.0 x001 x003) - из файла “Clouds”
                               Океанские волны 18.0.0 - из файла “Filter Gallery”
                               Очерченные края 18.0.0 - из файла “Filter Gallery”
                               Пастель 18.0.0 - из файла “Filter Gallery”
                               Перекрестные штрихи 18.0.0 - из файла “Filter Gallery”
                               Пластика 18.0.0 - из файла “Liquify”
                               Поддержка WIA 18.0.0 (2017.0.0 x001 x003) - из файла “WIASupport”
                               Поддержка нескольких процессоров 18.0.0 (2017.0.0 x001 x003) - из файла “MultiProcessor Support”
                               Полутоновой узор 18.0.0 - из файла “Filter Gallery”
                               Полярные координаты 18.0.0 - из файла “Standard MultiPlugin”
                               Почтовая бумага 18.0.0 - из файла “Filter Gallery”
                               Программы FastCore 18.0.0 (2017.0.0 x001 x003) - из файла “FastCore”
                               Программы MMXCore 18.0.0 (2017.0.0 x001 x003) - из файла “MMXCore”
                               Пуантилизм 18.0.0 - из файла “Standard MultiPlugin”
                               Радиальное размытие 18.0.0 - из файла “Standard MultiPlugin”
                               Разбиение 18.0.0 - из файла “Standard MultiPlugin”
                               Разбрызгивание 18.0.0 - из файла “Filter Gallery”
                               Размытие при малой глубине резкости 18.0.0 - из файла “Lens Blur”
                               Рассеянное свечение 18.0.0 - из файла “Filter Gallery”
                               Растушевка 18.0.0 - из файла “Filter Gallery”
                               Рваные края 18.0.0 - из файла “Filter Gallery”
                               Рельеф 18.0.0 - из файла “Filter Gallery”
                               Рендеринг таблицы поиска цвета NO VERSION - из файла “Export3DLUT”
                               Ретикуляция 18.0.0 - из файла “Filter Gallery”
                               Рисование на обороте 18.0.0 - из файла “Filter Gallery”
                               Рябь 18.0.0 - из файла “Standard MultiPlugin”
                               Свечение краев 18.0.0 - из файла “Filter Gallery”
                               Скручивание 18.0.0 - из файла “Standard MultiPlugin”
                               Смещение 18.0.0 - из файла “Standard MultiPlugin”
                               Соляризация 18.0.0 (2017.0.0 x001 x003) - из файла “Solarize”
                               Сохранить для Web 18.0.0 - из файла “Save for Web”
                               Среднее 18.0.0 (2017.0.0 x001 x003) - из файла “Average”
                               Стабилиз. изображения 18.0.0 - из файла “Shake Reduction”
                               Стандартные отклонения 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Стекло 18.0.0 - из файла “Filter Gallery”
                               Суми-э 18.0.0 - из файла “Filter Gallery”
                               Суммирование 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Сухая кисть 18.0.0 - из файла “Filter Gallery”
                               Сферизация 18.0.0 - из файла “Standard MultiPlugin”
                               Текстуризатор 18.0.0 - из файла “Filter Gallery”
                               Темные штрихи 18.0.0 - из файла “Filter Gallery”
                               Тушь 18.0.0 - из файла “Filter Gallery”
                               Уголь 18.0.0 - из файла “Filter Gallery”
                               Усреднение 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Устранение чересстрочной развертки 18.0.0 - из файла “Standard MultiPlugin”
                               Фильтр Camera Raw 9.10.1 - из файла “Camera Raw”
                               Фильтр кадрирования и выпрямления фотографии 18.0.0 - из файла “Standard MultiPlugin”
                               Фильтр раскладки изображения 18.0.0 (2017.0.0 x001 x003) - из файла “ChannelPort”
                               Фреска 18.0.0 - из файла “Filter Gallery”
                               Хром 18.0.0 - из файла “Filter Gallery”
                               Цвета NTSC 18.0.0 (2017.0.0 x001 x003) - из файла “NTSC Colors”
                               Цветная плитка 18.0.0 - из файла “Filter Gallery”
                               Цветные карандаши 18.0.0 - из файла “Filter Gallery”
                               Цветные полутона 18.0.0 - из файла “Standard MultiPlugin”
                               Целлофановая упаковка 18.0.0 - из файла “Filter Gallery”
                               Шпатель 18.0.0 - из файла “Filter Gallery”
                               Экспорт таблиц поиска цвета NO VERSION - из файла “Export3DLUT”
                               Экструзия 18.0.0 - из файла “Standard MultiPlugin”
                               Эксцессы 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Энтропия 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
                               Язык моделирования виртуальной реальности | VRML 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
                            Дополнительные и сторонние подключаемые модули: НЕТ
                            Повторяющиеся и отключенные внешние модули: НЕТ
                            Незагруженные внешние модули: НЕТ
                            Расширения:
                               Последние файлы  1.4.2 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                               com.adobe.inapp.purchase  2.10.56 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
                               Создать документ  1.4.2 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
                               Библиотеки  2.10.56 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
                               Начало  1.4.2 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                               com.adobe.experimentation.extension  2.0.0 — из файла “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
                               Темы Adobe Color  6.1.0 — из файла “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                               Экспортировать как  3.0.8 — из файла “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                               Device Preview  1.3.1 — из файла “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
                               com.adobe.preview.loader  1.3.1 — из файла “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
                            Установленные TWAIN-устройства: НЕТ
                            • 12. Re: Liquify crushing after 2nd use
                              There are a few things you can try
                              1. You appear to have two GPUs. Photoshop can have issues with that . see advice here
                              Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
                              2. There may be a later version of your video driver available , check the Nvidia site.
                              3. You are not using the current version of Photoshop CC2017. The current version is CC2017.1.1 (use the desktop app to update)
                              Dave
                              • 13. Re: Liquify crushing after 2nd use
                                Соль Level 1
                                I did all that... and still same..
                                here is the error full text:
                                Сигнатура проблемы:
                                  Имя события проблемы: BEX64
                                  Имя приложения: Photoshop.exe
                                  Версия приложения: 18.1.1.252
                                  Отметка времени приложения: 58fefd04
                                  Имя модуля с ошибкой: igdfcl64.dll
                                  Версия модуля с ошибкой: 10.18.10.3540
                                  Отметка времени модуля с ошибкой: 5338fa63
                                  Смещение исключения: 00000000013a66a0
                                  Код исключения: c0000005
                                  Данные исключения: 0000000000000008
                                  Версия ОС: 6.1.7601.2.1.0.768.2
                                  Код языка: 1049
                                  Дополнительные сведения 1: 9514
                                  Дополнительные сведения 2: 951445c422ef7264b9ef4c553aba5e5d
                                  Дополнительные сведения 3: 591d
                                  Дополнительные сведения 4: 591de41e57966ec8576f067b10ad4ec2
                                • 14. Re: Liquify crushing after 2nd use
                                  That shows an error in your integrated Intel display driver igdfcl64.dll .
                                  You say you have followed the previous advice - however part of that advice, linked in the previous post, involves disabling the Intel driver and ensuring the more powerful Nvidia driver is used by Photoshop.
                                  Please follow the advice in Section 7 of the link below
                                  Dave
                                  • 15. Re: Liquify crushing after 2nd use
                                    Соль Level 1
                                    I did all.... and this adobe spaces helper is there in the gpu settings...
                                    I don't understand what is going on. it's a circle of errors...
                                    Сигнатура проблемы:
                                      Имя события проблемы: APPCRASH
                                      Имя приложения: Adobe Spaces Helper.exe
                                      Версия приложения: 0.0.0.0
                                      Отметка времени приложения: 58fefe7b
                                      Имя модуля с ошибкой: libcef.dll
                                      Версия модуля с ошибкой: 3.2924.1537.0
                                      Отметка времени модуля с ошибкой: 584a4ed5
                                      Смещение исключения: 000000000049f61f
                                      Код языка: 1049
                                      Дополнительные сведения 1: 2763
                                      Дополнительные сведения 2: 2763835ca46e1006dffd622555ea5f04
                                      Дополнительные сведения 3: 6907
                                      Дополнительные сведения 4: 6907b68c5c0d4bd24f4ca6e9b6246b0e
