Hello!
I have a problem, and non of advices didn't help me.
The liquify filter in PS CC 2017 crushing after 2nd use I already change the video card for more good.
It was iNvidia GeForce (Gigabyte) GTX 760 and now it is iNvidia GeForce (Gigabyte) GTX 1050 ti
I don't need the latest versions if PS CC cuz I need the new functional in 2017.
The strange thing is - then i just setup PS all functional in liquify filter is working, but if try to use it again - the proramm crushing...
Does turning off »Use Graphics Processor« in the Performance Preferences (Photoshop > Preferences > Performance > Graphic Processor Settings) and restarting Photoshop have any bearing on the issue?
What have you done for trouble-shooting so far?
Restoring Preferences after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved might be a good starting point:
https://helpx.adobe.com/photoshop/kb/basic-trouble-shooting-steps.html
I turned off this »Use Graphics Processor« and liquify was working but not the "face" functional. I read a lot of variations of solvation of this problem, and all of them tell it's all becouse of video card, but I set new one, much better, and if the PS's full functional doesn't want to work with normal cards and want just "top" it is very bad thing.
Restarting doesn't help too. Just if reinstall all CC it will work just 1 time and then crushing again.
I changed the cashe level, and change drawing settings to basic.
I actually bought new video card! And nothing... All this functional working on the laptop with geforce 920 mx but not on the pc with 1050 ti.. I belive it's strange..
Could the problem be in anything else?
Neither card seems to be on the list of tested ones
Photoshop graphics processor (GPU) card FAQ
so it seems likely the issue is indeed connected to those.
--- I had the 700 (gtx 760)series and had same situation! PS crushed after opening lyquiy filter.
nVidia GeForce GTX 965M & 980M
What?
Only two nVidia GeForce GTX cards appear to be listed.
So your "very open" answer saying what if adobe didn't tests something and it's works (like my laptop 920mx) it's an accidental coincidence and if none of others card don't working it's will be tested later or never.
I don't want to thank any of you, guys. You just copy and paste things and don't trying to understand the problem. ALL was working at the 1st time. It's mean what my card CAN run with that functional, but PS crushing after 2d.
Moderators, please close this topic, cuz I don't belive here will be any working advice, just copy and paste.
Just to clarify: I am not an Adobe employee but a Photoshop user.
Have you updated the GPU driver yet?
I tried pointing out that you seem to have misunderstood the list and referenced a different class of GeForce cards.
In any case Adobe has tested Photoshop with several GPU cards, if one uses others then there is no guarantee Photoshop can utilise their resources successfully.
You may want to start a new thread, maybe someone else will be able to help you better.
Hi
This is predominantly a user to user forum (although occasionally Adobe staff do join , you will see them clearly with the red Staff badge).
Can you post your full system info (from Photoshop menu Help - System info - Copy) . This may allow someone to spot a problem and try to help you.
Dave
Версия Adobe Photoshop: 2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006 ( x64)
Количество запусков: 0
Версия: 7 SP1
Архитектура системы: cемейство процессоров Intel: 6, модель: 12, пошаговая обработка: 3 с MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Счетчик физического процессора: 4
Частота процессора: 3400 МГц
Встроенная память: 8061 МБ
Свободная память: 2 МБ
Память, доступная для программы Photoshop: 6961 МБ
Память, используемая программой Photoshop: 70 %
Слои-псевдонимы: ^0
Палитра модификатора: Отключено.
Многотональная 3D-печать: Отключено.
Highbeam: Включен.
Размер фрагмента изображения: 1024 Кб
Уровней кэш-памяти изображений: 4
Просмотр шрифта: Средний
TextComposer: Латиница
Экран: 1
Область отображения: сверху= 0, слева= 0, снизу= 1080, справа= 1920
Экран: 2
Область отображения: сверху= 192, слева= -1920, снизу= 1272, справа= 0
Экран: 3
Область отображения: сверху= 1080, слева= 0, снизу= 2160, справа= 1920
Отрисовка OpenGL: Включен.
Поддержка старых графических процессоров OpenGL: Не обнаружено.
Режим отрисовки OpenGL: Расширенный
Обычный режим OpenGL: Верно.
Расширенный режим OpenGL: Верно.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=2
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="NVIDIA GeForce GTX 1050"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="21.21.13.7595"
glgpu[0].GLRectTextureSize=32768
glgpu[0].GLRenderer="GeForce GTX 1050/PCIe/SSE2"
glgpu[0].GLRendererID=7297
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
glgpu[0].GLDriverDate="20161116000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 "
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1297
clgpu[0].CLName="Intel(R) HD Graphics 4600"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="10.18.10.3540"
clgpu[0].CLBandwidth=1.61628e+10
clgpu[0].CLCompute=112.935
glgpu[1].GLVersion="4.1"
glgpu[1].IsIntegratedGLGPU=1
glgpu[1].GLMemoryMB=2112
glgpu[1].GLName="Intel(R) HD Graphics 4600"
glgpu[1].GLVendor="NVIDIA Corporation"
glgpu[1].GLVendorID=32902
glgpu[1].GLDriverVersion="10.18.10.3540"
glgpu[1].GLRectTextureSize=32768
glgpu[1].GLRenderer="GeForce GTX 1050/PCIe/SSE2"
glgpu[1].GLRendererID=1042
glgpu[1].HasGLNPOTSupport=1
glgpu[1].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32"
glgpu[1].GLDriverDate="20140330000000.000000-000"
glgpu[1].CanCompileProgramGLSL=1
glgpu[1].GLFrameBufferOK=1
glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[1].CLPlatformVersion="1.2"
clgpu[1].CLDeviceVersion="1.2 CUDA"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=2048
clgpu[1].CLName="GeForce GTX 1050"
clgpu[1].CLVendor="NVIDIA Corporation"
clgpu[1].CLVendorID=4318
clgpu[1].CLDriverVersion="375.95"
clgpu[1].CLBandwidth=8.91661e+10
clgpu[1].CLCompute=769.247
Тип лицензии: Подписка
Серийный номер: 90970964379604619012
GUIDBucket:
bucket: 129
test: ReduceUXFriction
Программная папка: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Путь для временных файлов: C:\Users\Ki\AppData\Local\Temp\
Асинхронный ввод/вывод рабочей памяти Photoshop включен
Рабочие диски:
Загрузочный, 931,3Г, 461,3Г пусто
Папка обязательных подключаемых модулей: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\
Папка основных внешних модулей: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Установленные компоненты:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2016/09/17-17:22:04 79.577309 79.577309
AdbePM.dll PatchMatch 2016/05/17:03:10:18 1.573920 1.573920
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.577309 79.577309
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2016/09/17-17:22:04 79.577309 79.577309
ahclient.dll AdobeHelp Dynamic Link Library 2.0.0.2
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.47 BuildVersion: 10.0; BuildDate: Thu Sep 1 2016 5:16:17) 1.000000
ARE.dll ARE 2016/09/17-17:22:04 79.577309 79.577309
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2016/09/17-17:22:04 79.577309 79.577309
BIBUtils.dll BIBUtils 2016/09/17-17:22:04 79.577309 79.577309
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.1.0.1 2.1.0.1
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2016/09/17-17:22:04 79.577309 79.577309
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/01/26-16:09:33 80.1060872 80.1060872
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.1
JP2KLib.dll JP2KLib 2016/05/26-01:08:58 79.262945 79.262945
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.0.0
Plugin.dll Adobe Photoshop CC 2017 18.0.0
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.0.0
PSViews.dll Adobe Photoshop CC 2017 18.0.0
SCCore.dll ScCore 2016/01/26-16:09:33 80.1060872 80.1060872
SVGRE.dll SVGRE 79.577309 79.577309
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Обязательные подключаемые модули:
"Умное" размытие 18.0.0 - из файла “Standard MultiPlugin”
3D Studio 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
3D-модуль Photoshop 18.0.0 (2017.0.0 x001 x003) - из файла “Photoshop3DEngine”
BMP 18.0.0 - из файла “Standard MultiPlugin”
Camera Raw 9.10.1 - из файла “Camera Raw”
Cineon 18.0.0 (2017.0.0 x001 x003) - из файла “Cineon”
Collada 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
CompuServe GIF 18.0.0 - из файла “Standard MultiPlugin”
Dicom 18.0.0 - из файла “Dicom”
Eazel Acquire 18.0.0 (2017.0.0 x001 x003) - из файла “EazelAcquire”
Flash 3D 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
Google Earth 4 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
HDRMergeUI 18.0.0 - из файла “HDRMergeUI”
HSB/HSL 18.0.0 - из файла “Standard MultiPlugin”
IFF формат 18.0.0 - из файла “Standard MultiPlugin”
IGES 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
JPEG 2000 18.0.0 - из файла “JPEG2000”
Matlab Operation 18.0.0 (2017.0.0 x001 x003) - из файла “ChannelPort”
Measurement Core 18.0.0 (2017.0.0 x001 x003) - из файла “MeasurementCore.8me”
OpenEXR 18.0.0 - из файла “Standard MultiPlugin”
PCX 18.0.0 (2017.0.0 x001 x003) - из файла “PCX”
Photoshop Touch 14.0 - из файла “PSDX”
Pixar 18.0.0 (2017.0.0 x001 x003) - из файла “Pixar”
PLY 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
PNG 18.0.0 - из файла “Standard MultiPlugin”
Portable Bit Map 18.0.0 (2017.0.0 x001 x003) - из файла “PBM”
PRC 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
ScriptingSupport 18.0.0 - из файла “ScriptingSupport”
Spaces 18.0.0 - из файла “Spaces”
STL 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
Targa 18.0.0 - из файла “Standard MultiPlugin”
U3D 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
Wavefront|OBJ 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
Wireless Bitmap 18.0.0 (2017.0.0 x001 x003) - из файла “WBMP”
Адаптивный широкий угол 18.0.0 - из файла “Adaptive Wide Angle”
Акварель 18.0.0 - из файла “Filter Gallery”
Акцент на краях 18.0.0 - из файла “Filter Gallery”
Аппликация 18.0.0 - из файла “Filter Gallery”
Ассиметрия 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Аэрограф 18.0.0 - из файла “Filter Gallery”
Блик 18.0.0 - из файла “Standard MultiPlugin”
Ветер 18.0.0 - из файла “Standard MultiPlugin”
Витраж 18.0.0 - из файла “Filter Gallery”
Волна 18.0.0 - из файла “Standard MultiPlugin”
Волокна 18.0.0 - из файла “Standard MultiPlugin”
Волшебный карандаш 18.0.0 - из файла “Filter Gallery”
Галерея фильтров 18.0.0 - из файла “Filter Gallery”
Гипс 18.0.0 - из файла “Filter Gallery”
Губка 18.0.0 - из файла “Filter Gallery”
Диапазон 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Дисторсия 18.0.0 - из файла “Standard MultiPlugin”
Зернистость фотопленки 18.0.0 - из файла “Filter Gallery”
Зерно 18.0.0 - из файла “Filter Gallery”
Зигзаг 18.0.0 - из файла “Standard MultiPlugin”
Излучение 18.0.0 (2017.0.0 x001 x003) - из файла “Radiance”
Искривление 18.0.0 - из файла “Standard MultiPlugin”
Исправление перспективы 18.0.0 - из файла “VanishingPoint”
Кадрировать и выпрямить фотографию 18.0.0 (2017.0.0 x001 x003) - из файла “CropPhotosAuto”
Контуры в Illustrator 18.0.0 - из файла “Standard MultiPlugin”
Коррекция дисторсии 18.0.0 - из файла “Lens Correction”
Кракелюры 18.0.0 - из файла “Filter Gallery”
Кристаллизация 18.0.0 - из файла “Standard MultiPlugin”
Ксерокопия 18.0.0 - из файла “Filter Gallery”
Линогравюра 18.0.0 - из файла “Filter Gallery”
Максимальное 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Масляная живопись 18.0.0 - из файла “Filter Gallery”
Медиана 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Мел и уголь 18.0.0 - из файла “Filter Gallery”
Меццо-тинто 18.0.0 - из файла “Standard MultiPlugin”
Минимальное 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Мозаичные фрагменты 18.0.0 - из файла “Filter Gallery”
Мокрая бумага 18.0.0 - из файла “Filter Gallery”
Наклонные штрихи 18.0.0 - из файла “Filter Gallery”
Неоновый свет 18.0.0 - из файла “Filter Gallery”
Несовпадения 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Обводка 18.0.0 - из файла “Filter Gallery”
Облака 18.0.0 (2017.0.0 x001 x003) - из файла “Clouds”
Облака с наложением 18.0.0 (2017.0.0 x001 x003) - из файла “Clouds”
Океанские волны 18.0.0 - из файла “Filter Gallery”
Очерченные края 18.0.0 - из файла “Filter Gallery”
Пастель 18.0.0 - из файла “Filter Gallery”
Перекрестные штрихи 18.0.0 - из файла “Filter Gallery”
Пластика 18.0.0 - из файла “Liquify”
Поддержка WIA 18.0.0 (2017.0.0 x001 x003) - из файла “WIASupport”
Поддержка нескольких процессоров 18.0.0 (2017.0.0 x001 x003) - из файла “MultiProcessor Support”
Полутоновой узор 18.0.0 - из файла “Filter Gallery”
Полярные координаты 18.0.0 - из файла “Standard MultiPlugin”
Почтовая бумага 18.0.0 - из файла “Filter Gallery”
Программы FastCore 18.0.0 (2017.0.0 x001 x003) - из файла “FastCore”
Программы MMXCore 18.0.0 (2017.0.0 x001 x003) - из файла “MMXCore”
Пуантилизм 18.0.0 - из файла “Standard MultiPlugin”
Радиальное размытие 18.0.0 - из файла “Standard MultiPlugin”
Разбиение 18.0.0 - из файла “Standard MultiPlugin”
Разбрызгивание 18.0.0 - из файла “Filter Gallery”
Размытие при малой глубине резкости 18.0.0 - из файла “Lens Blur”
Рассеянное свечение 18.0.0 - из файла “Filter Gallery”
Растушевка 18.0.0 - из файла “Filter Gallery”
Рваные края 18.0.0 - из файла “Filter Gallery”
Рельеф 18.0.0 - из файла “Filter Gallery”
Рендеринг таблицы поиска цвета NO VERSION - из файла “Export3DLUT”
Ретикуляция 18.0.0 - из файла “Filter Gallery”
Рисование на обороте 18.0.0 - из файла “Filter Gallery”
Рябь 18.0.0 - из файла “Standard MultiPlugin”
Свечение краев 18.0.0 - из файла “Filter Gallery”
Скручивание 18.0.0 - из файла “Standard MultiPlugin”
Смещение 18.0.0 - из файла “Standard MultiPlugin”
Соляризация 18.0.0 (2017.0.0 x001 x003) - из файла “Solarize”
Сохранить для Web 18.0.0 - из файла “Save for Web”
Среднее 18.0.0 (2017.0.0 x001 x003) - из файла “Average”
Стабилиз. изображения 18.0.0 - из файла “Shake Reduction”
Стандартные отклонения 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Стекло 18.0.0 - из файла “Filter Gallery”
Суми-э 18.0.0 - из файла “Filter Gallery”
Суммирование 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Сухая кисть 18.0.0 - из файла “Filter Gallery”
Сферизация 18.0.0 - из файла “Standard MultiPlugin”
Текстуризатор 18.0.0 - из файла “Filter Gallery”
Темные штрихи 18.0.0 - из файла “Filter Gallery”
Тушь 18.0.0 - из файла “Filter Gallery”
Уголь 18.0.0 - из файла “Filter Gallery”
Усреднение 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Устранение чересстрочной развертки 18.0.0 - из файла “Standard MultiPlugin”
Фильтр Camera Raw 9.10.1 - из файла “Camera Raw”
Фильтр кадрирования и выпрямления фотографии 18.0.0 - из файла “Standard MultiPlugin”
Фильтр раскладки изображения 18.0.0 (2017.0.0 x001 x003) - из файла “ChannelPort”
Фреска 18.0.0 - из файла “Filter Gallery”
Хром 18.0.0 - из файла “Filter Gallery”
Цвета NTSC 18.0.0 (2017.0.0 x001 x003) - из файла “NTSC Colors”
Цветная плитка 18.0.0 - из файла “Filter Gallery”
Цветные карандаши 18.0.0 - из файла “Filter Gallery”
Цветные полутона 18.0.0 - из файла “Standard MultiPlugin”
Целлофановая упаковка 18.0.0 - из файла “Filter Gallery”
Шпатель 18.0.0 - из файла “Filter Gallery”
Экспорт таблиц поиска цвета NO VERSION - из файла “Export3DLUT”
Экструзия 18.0.0 - из файла “Standard MultiPlugin”
Эксцессы 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Энтропия 18.0.0 (2017.0.0 x001 x003) - из файла “statistics”
Язык моделирования виртуальной реальности | VRML 18.0.0 (2017.0.0 x001 x003) - из файла “U3D”
Дополнительные и сторонние подключаемые модули: НЕТ
Повторяющиеся и отключенные внешние модули: НЕТ
Незагруженные внешние модули: НЕТ
Расширения:
Последние файлы 1.4.2 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
com.adobe.inapp.purchase 2.10.56 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
Создать документ 1.4.2 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
Библиотеки 2.10.56 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
Начало 1.4.2 — из файла “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
com.adobe.experimentation.extension 2.0.0 — из файла “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Темы Adobe Color 6.1.0 — из файла “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Экспортировать как 3.0.8 — из файла “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Device Preview 1.3.1 — из файла “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.1 — из файла “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Установленные TWAIN-устройства: НЕТ
There are a few things you can try
1. You appear to have two GPUs. Photoshop can have issues with that . see advice here
Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
2. There may be a later version of your video driver available , check the Nvidia site.
3. You are not using the current version of Photoshop CC2017. The current version is CC2017.1.1 (use the desktop app to update)
Dave
I did all that... and still same..
here is the error full text:
Сигнатура проблемы:
Имя события проблемы: BEX64
Имя приложения: Photoshop.exe
Версия приложения: 18.1.1.252
Отметка времени приложения: 58fefd04
Имя модуля с ошибкой: igdfcl64.dll
Версия модуля с ошибкой: 10.18.10.3540
Отметка времени модуля с ошибкой: 5338fa63
Смещение исключения: 00000000013a66a0
Код исключения: c0000005
Данные исключения: 0000000000000008
Версия ОС: 6.1.7601.2.1.0.768.2
Код языка: 1049
Дополнительные сведения 1: 9514
Дополнительные сведения 2: 951445c422ef7264b9ef4c553aba5e5d
Дополнительные сведения 3: 591d
Дополнительные сведения 4: 591de41e57966ec8576f067b10ad4ec2
That shows an error in your integrated Intel display driver igdfcl64.dll .
You say you have followed the previous advice - however part of that advice, linked in the previous post, involves disabling the Intel driver and ensuring the more powerful Nvidia driver is used by Photoshop.
Please follow the advice in Section 7 of the link below
Dave
I did all.... and this adobe spaces helper is there in the gpu settings...
I don't understand what is going on. it's a circle of errors...
Сигнатура проблемы:
Имя события проблемы: APPCRASH
Имя приложения: Adobe Spaces Helper.exe
Версия приложения: 0.0.0.0
Отметка времени приложения: 58fefe7b
Имя модуля с ошибкой: libcef.dll
Версия модуля с ошибкой: 3.2924.1537.0
Отметка времени модуля с ошибкой: 584a4ed5
Смещение исключения: 000000000049f61f
Код языка: 1049
Дополнительные сведения 1: 2763
Дополнительные сведения 2: 2763835ca46e1006dffd622555ea5f04
Дополнительные сведения 3: 6907
Дополнительные сведения 4: 6907b68c5c0d4bd24f4ca6e9b6246b0e
