I have designed one template and planning to send data from database(sql server) and I want to run adobe after effect from asp.net with opening adobe after effects with simple database example. But now i am unable to integrate from asp.net and sql server. I am able to integrate with excelsheet but not able to integrate with Sql server. Please help me.
Thanks & Regards
Shankar Chaurasia
[Moving out of the Forum comments forum (which is for issues with these forums themselves) and into a product-specific support forum - moderator]
Honestly: I don't have the slightest idea what you are talking about. Sorry, but the way you are asking your question is like asking if a type A plug might fit into a type B socket and vice versa without actually specifiying what those connections could possibly be. You'd have to be a hundred times more detailed and specific to even get close to a sensible reply, but even then your question is so exotic you should not hope for anyone to have the immediate answer.
Mylenium
Sir,
I am now taking help of reactjs javascript library to generate .jsx file that will fetch the data from sql server and convert to composition file for the given AE template and render the output. Is this approach is the best. Please suggest me if any other way to do the same.
Hi ChaurasiyaS,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
You don't say what method you are using to access AE. If you don't get help here after doing that, try this subforum:
