So I've made my work in a 336x380 canvas. When I use align to stage it works perfectly. But if I change the canvas to, for example, 728x90 it won't work properly. If I use align to stage it doesn't center with the canvas. Is there a way to fix this?
No, that's your issue. If you try to align within a symbol, it will be aligning based on the size of the symbol, not the size of the main stage.
If you need to align things to the main stage from inside a symbol, a trick would be to create a rectangle the size of your stage, make it a guide layer inside your symbol, and align your objects to that.
Otherwise, you could just keep always the items in your symbol at the 0 x and y positions, and align to the stage via the main timeline instead.
I just tested this and it worked fine.
How, EXACTLY, are you changing the canvas size?
First, thanks for your reply.
I work in a HTML5 canvas. Under properties there is size: W: 336 H: 280. When I change the numbers to say: W: 728 H: 90 and align to the middle of the canvas, it doesn't go to the middle. Maybe I have a setting wrong or something, because I can't find the problem online.
How, EXACTLY, are you attempting to align something to the middle of the canvas?
1. I select the object I want to align to the middle of the canvas
2. I make sure I've 'Align to stage' checked
3. Under 'align' menu I click align vertical center or align horizontal centre
4. Object centres as if the canvas has the old size
Weird, that works fine for me. What version of Animate are you running?
Are you trying to align things inside a symbol, or on the main timeline?
I'm trying to align in a symbol, this should work the same right?
Thank you very much, that is where i was wrong.
