I was sent a hardcopy of a 10-page scanned document and it has a dark grey background. I need to make a pdf of it. Is there a way I can remove the grey background from the pages using Adobe Acrobat Pro DC?
[Moved from the Lounge (which is where you can "connect with your peers" from across all of Adobe's products for conversations that don't directly relate to help and support) to a product-specific support forum - moderator]
Can you post some screenshots? What you are probably seeing is the grey background of the reader not part of the actual document?
You should use an image editing application (like Photoshop) to do that.
Hi Brad,
It's a hardcopy that was printed from a scan probably too many times and now there is just so much noise in the background that it is really speckled. If I use Photoshop, do I have to select and then select the inverse? This seems like it would take too much time. Is there a way in PS to just lighten the background of a multi-page pdf?
