Creating links to other topics very slow
Oct 03, 2008 Oct 03, 2008
Hi, I have RH 7 and when creating links from one topic to another it takes a long time for the dialog boxes to appear. I have about 10 links per topic and at three minutes per link, that's a lot of time. Thanks, Becky
705
Hi Becky.
Rule No.1 is never run your RH project from a network drive. Is your desktop truly local or part of the network?
My desktop is truly local, which is where the working folder of my project is. When I publish for webhelp, the output files are on a network drive.
Engaged ,
Oct 09, 2008 Oct 09, 2008
Becky,
It is indeed a lot of time. How many topics do you have in your project? I have seen slow performance loading the dialog for inserting images, when the number of images in a project gets large, but never with links.
This is likely a resource issue with Windows. Do you see similar problems with other programs? Do you have a lot of other programs running? And do you have any resource hogs like Google toolbar? If you close other things do you see an improvement?
John
Are you using RH HTML or RH for Word?
Advisor ,
Oct 10, 2008 Oct 10, 2008
Perforce and ClearCase (source control tools) often don't play well with RH, depending on how your IT peeps have it set up.
Good luck,
Leon
Thanks for your responses. The project has 1000 topics that represent 30 chapters of a manual. There's not any source control software used. I'm using Robohelp HTML. I don't run any other programs when I'm using Robohelp; I have 1GB RAM, 80 GB hard drive.
What is causing it to take so long to insert links?
Guest
Hi Becky. I'm popping in here because this was happening to me recently - and all I did to resolve it was to rebuild the CPD file. I renamed it in the project directory (renamed accounting.cpd to accounting.old) and then reopened the project. It took several minutes to rebuild the file, but then building links and moving files, creating new folders - all the stuff the CPD file keeps an eye on - went much more smoothly.
I usually keep an eye on the size of the CPD file. It it jumps all of a sudden, that's also a clue that the file is getting bloated and should be rebuilt.
Good luck!
Hi Becky
In addition to LMarden's fine advice, I might also ask exactly how you are creating your links. If you have been selecting text, then opening the Hyperlink dialog you may find it much quicker to use the drag and drop method. Using that method involves simply locating the topic you wish to link to over in your Project Manager pane. Then clicking the topic and dragging it from there to the selected text to establish the link.
Cheers... Rick
Guest
Another thing is to use a real folder under your hard drive not a folder in My documents..
Advisor ,
...which reminds me that someone mentioned awhile ago that some IT peeps like to store your My Documents stuff in a "virtual folder" on a network (those sneaky rascals!).
Good luck,
Leon
Guest
Nov 26, 2008 Nov 26, 2008
I'm having the same, or a similar, problem. I'm trying to insert lots (more than a thousand) of help jumps into a Word 2007 document and it's taking a minute or so per topic. I'm running on a laptop with an electronic disk. I don't see any CPD files to delete. I tried dragging a help topic from my project window to the Word document, but that didn't seem to do anything. Something I thought would work, but whch didn't, was to create the links as Word 2007 links (which is fast), then do a conversion and convert links to help jumps. I still haven't figured out why that didn't work. If there are any other suggestions, that would be appreciated.
William
RoboHelp Documentation
Download Adobe RoboHelp
