15 Replies Latest reply: Oct 10, 2008 8:16 AM by Newsgroup_User RSS
    Blank index page
    Stuart Haiz Community Member
      I'm having a really frustrating problem with my site index.php page - sometimes it shows blank & needs refreshing before the content can be seen.
      This happens erratically on all browsers & I don't seem to be able to find the solution. My doc type is OK so I would appreciate an expert eye.
      Here's my page link.
        • 1. Re: Blank index page
          samismynickname
          i dont know what is causing the issue, but i know how i would solve it.
          copy the page and create a new one.
          start with the basics of the page and gradually add code in pieces. this way you can figure out what section of your code is causing the issue.
          • 2. Re: Blank index page
            Good idea - thanks. I'll give that a go.
            • 3. Re: Blank index page
              Newsgroup_User Community Member
              On Thu, 9 Oct 2008 14:48:19 +0000 (UTC), "Siriunson"
              You have 28 opening <div> tags (why so many?) and 29 closing </div>
              tags. I would guess that could be confusing browsers.
              Gary
              • 4. Re: Blank index page
                Thank you Gary - I'll look into that. I have a lot of <divs> because I have a lot of nested elements such as my buttons.
                The idea was that I have built them hoping to be able to swap stylesheets at a later date so the page can be customized on the fly...
                • 5. Re: Blank index page
                  On Thu, 9 Oct 2008 16:56:23 +0000 (UTC), "Siriunson"
                  It just looks like what we commonly refer to as <div> soup. Putting
                  each button inside a separate <div> tag just doesn't make sense. Using
                  something with some semantic meaning is usually more productive.
                  Good luck!
                  Gary
                  • 6. Re: Blank index page
                    Fair enough! Without asking for you to rebuild my page, can you give me any pointers to tutorials or best practices that would help me avoid the div-fest.
                    At the moment, I'm using a basic header, side-bar, main content & footer arrangement (in a wrapper), with some nesting for buttons etc.
                    Back to my original query, if I enter the site at another point I don't get the blank page issue, even though the structure is essentially the same.
                    • 7. Re: Blank index page
                      On Thu, 9 Oct 2008 18:56:42 +0000 (UTC), "Siriunson"
                      How about something like changing the <div> soup nav bar from 10 <div>
                      tags to a simple <ul>?
                      Did you find and remove the extra closing </div>?
                      Gary
                      • 8. Re: Blank index page
                        "Gary White" <reply@newsgroup.please> wrote in message
                        news:rqbse45ue8q46vdcshsbq174cj01b44ekm@4ax.com...
                        > You have 28 opening <div> tags ...
                        Okay, but thank God, at least there aren't any tables. :-) I sometimes
                        use as many as 1 of them on a page.
                        Patty Ayers | www.WebDevBiz.com
                        Free Articles on the Business of Web Development
                        Web Design Contract, Estimate Request Form, Estimate Worksheet
                        • 9. Re: Blank index page
                          Yet another reason to avoid <div> soup. When a page has that many divs
                          tracing down a missing open or close tag can be painful.
                          Walt
                          news:g12te4heqhk1sttorghne257u83jcg89rl@4ax.com...
                          >>any
                          >>div-fest.
                          >> get
                          > Gary
                          • 10. Re: Blank index page
                            I found an entire <div> that I didn't need! Didn't find the extra closing div though. I used the parent tag selector in code view but still couldn't see the extra one. I think my problem was due to a script in my Flash movie. Have gone over to using FLVPlayback component instead of NetConnection & it seems to be OK.
                            The Spry Accordion added 7 extra <div>s, plus my nested buttons all added up to a bigger collection than originally intended. I'm on clean-up mode now - maybe I'll find the missing <div>.
                            Thanks for all the help.
                            • 11. Re: Blank index page
                              Gary
                              Good thinking. I may have to reslice my header buttons as some may be a pixel different due to my Photoshop slicing.
                              • 12. Re: Blank index page
                                On Thu, 9 Oct 2008 18:58:13 -0400, "P@tty Ayers ~ACE"
                                <LOL> And there are also no <font> tags!
                                Gary
                                • 13. Re: Blank index page
                                  On Thu, 9 Oct 2008 16:22:55 -0700, "Walt F. Schaefer"
                                  Exactly. I started to look for where the extra might be, but there
                                  were just too many to even begin to find it.
                                  Gary
                                  • 14. Re: Blank index page
                                    This is where the embarrassed smiley is needed...
                                    • 15. Re: Blank index page
                                      On Fri, 10 Oct 2008 12:18:16 +0000 (UTC), "Siriunson"
                                      >Gary
                                      > tags to a simple
                                      Good luck!
                                      Gary
