I'm currently using RoboHelp HTML 11 on a Windows 7 machine. I'm taking a look at the insides of my project's HHC file and have a question about some of its contents.
In many of the topic titles, I'm using User Defined Variables to control a product name. When I open the HHC in a text editor to view its contents, I notice that the variables used are always followed by some numbers. For example:
<item name="Topic Name" link="TopicFileName.htm" variable="Sample_Name,0,14,"></item>
For the same variable, the numbers are mostly consistent throughout the file but there are a few instances where the numbers are different.
Out of curiosity, what do these numbers following my variables within the HHC file indicate?
Okay, I believe I've sussed out the meanings.
Take a look at the image below.
In this image the value of state is MO. As you can see on line 9, the word "Absentee" is listed. And if you add the space, that would consume nine characters. So we now have 9, 2. With the two indicating the number of characters the variable now contains.
Cheers... Rick
Hi there
I did some poking around and here's what I'm seeing. I created a variable and named it state. The value is Ohio. And I created a second variable and named it City. Its value is Cleveland.
Here is the TOC innards:
I note that the lines holding the state variable show a 4. Which seems to coincide nicely with the number of letters in Ohio. And the City variable shows a 9, which, oddly coincides with the number of letters in Cleveland. So my guess for the varying numbers highlighted in the image above is that it's kind of a checksum or something to that effect to track how many characters the variable value contain.
As for the leading 0, I don't have any explanation quite yet.
Cheers... Rick
Cheers... Rick
Huh, such a simple answer. I have two sets of Single Source Layouts that I generate and my team mates were thinking the numbers had something to do with that and we never would've guessed that it's a simple count of the characters. Thank you very much for your help, Rick!!
