I have to merge cells of table using script. I have a table as shown below,
ROD DIAMETER | ROD DIAMETER TOLERANCE 1 | ROD DIAMETER TOLERANCE 2 | HOUSING DIAMETER | HOUSING DIAMETER TOLERANCE 1 | HOUSING DIAMETER TOLERANCE 2 |
1.750 | +.000 | -.003 | 2.174 | +.004 | +.000 |
2.500 | +.000 | -.004 | 3.116 | +.005 | +.000 |
5.000 | +.000 | -.004 | 5.616 | +.005 | +.000 |
Now, I have to merge cells as shown below,
ROD DIAMETER | HOUSING DIAMETER | HOUSING DIAMETER TOLERANCE 1 | HOUSING DIAMETER TOLERANCE 2 |
1.75 '+.000 '-.003 | 2.174 | +.004 | +.000 |
2.500 '+.000 '-.004 | 3.116 | +.005 | +.000 |
5.000 '+.000 '-.004 | 5.616 | +.005 | +.000 |
How can I merge cells using scripts. Please do guide me!
Revathi
There is a script from Indiscripts that is exactly for this purpose:
Indiscripts :: Improve the Way you Merge Cells in InDesign
The script works most of the time but I have noticed from time to time that despite selecting the cells and running the script, nothing happens, but if I select fewer cells, then the script works again. Bizarre.
Bonjour,
Ceci peux vous guidez,
Ex :
var ligne04 = "Test: ";
if(app.documents.length != 0){
if(app.selection.length != 0 && app.selection[0].constructor.name == 'Table'){
var nomTableau = app.selection[0];
nomTableau.rows[0].cells.item(0).merge(nomTableau.rows[0].cells.item(1));
nomTableau.rows[0].cells[0].texts[0].insertionPoints[0].contents = ligne04;
exit();
else{
alert("Selection un tableau");
exit();
else{
alert("Ouvrait un document et Mettre son cuseur dans le points de départ");
exit();
Hi Colin,
Thanks for your response.I have my cells as ,
Using the script I was able to merge my cells as ,
1.750 | +.000 -.003 |
2.500 | +.000 -.004 |
5.000 | +.000 -.004 |
I tried to merge it as,
I tried to change the row values to columns but the merging of cells remain the same. Please do guide me.
Revathi
Hi Revathi,
if "the script" is the one written by Marc Autret—SmartCellMerge.js—you can change the separator to the one you like to see. I guess it'll be "End of Paragraph" {EOP} .
Or use any other sequence of characters.
Marc defined three that you can insert with buttons:
"Tabulator", "End of Paragraph" and "End of Line".
To get to that dialog where you can define this, run the script without selecting anything.
Marc Autret is describing this in detail.
http://www.indiscripts.com/blog/public/data/improve-the-way-you-merge-cells-in-indesign/_en_04.png
Uwe
Hi Uwe,
Thanks for your guidance.I got it.
Now I have cells as
ITEM_NO | ID | OD | Ht | GROOVE WIDTH | GROOVE WIDTH TOLERANCE 1 | GROOVE WIDTH TOLERANCE 2 |
BRS-17502 | 1.750 | 2.174 | 0.166 | 0.166 | +.010 +.000 | |
BRS-25003 | 2.500 | 3.116 | 0.247 | 0.247 | +.010 +.000 | |
BRS-50003 | 5.000 | 5.616 | 0.247 | 0.247 | +.010 +.000 |
I have to merge it as:
BRS-17502 | 1.750 | 2.174 | 0.166 | 0.16 +.010 +.000 |
BRS-25003 | 2.500 | 3.116 | 0.247 | 0.247 +.010 +.000 |
BRS-50003 | 5.000 | 5.616 | 0.247 | 0.247 +.010 +.000 |
How shall I get it?Please do guide.
Revathi V
Hi Revathi,
I guess you need a tab between 0.16 and the +.010 and a tab before +.000 as well.
That means you need an extra step before merging the value cells of GROOVE WIDTH and GROOVE WIDTH TOLERANCE.
You could select all value cells of GROOVE WIDTH and run a Find/Replace GREP on the selected cells:
Something like that:
Find:
Replace:
\t$0
And then do the merge of GROOVE WIDTH and GROOVE WIDTH TOLERANCE with no sepaparation character.
1. After GREP Find/Replace:
2. Changing preferences with Marc's SmartCellMerge script.
No separation character applied.
3. After the merge:
Uwe
Hey!
Sorry to resurrect this topic, but I am trying to use the script to merge Vertical, and when I try to merge the rows of column 10 with 11 it does not work.
Anybody has fixed this issue? - I guess it's some bug in the code but I can not find it...
Here are some tests.
For reference I am using a 21x3 col table and merging 2 rows.
C2-C21 - OK
C3-C21 - OK
C4-C21 - NO
C10-C21 - NO
C11-C21 - OK
Any JS masters around?
Marc's script does that to me from time to time. I find if I make a smaller selection, that will work, so it may mean running the script a couple of times.
Dirk becker also has a script that works as a startup script but serves a similar purpose: Scripts for InDesign Tables
Thanks Colin
