Merging of table cells using scripts in InDesign
Jun 06, 2017 Jun 06, 2017
I have to merge cells of table using script. I have a table as shown below,
ROD DIAMETER
ROD DIAMETER TOLERANCE 1
ROD DIAMETER TOLERANCE 2
HOUSING DIAMETER
HOUSING DIAMETER TOLERANCE 1
HOUSING DIAMETER TOLERANCE 2
1.750
+.000
-.003
2.174
+.004
+.000
2.500
+.000
-.004
3.116
+.005
+.000
5.000
+.000
-.004
5.616
+.005
+.000
Now, I have to merge cells as shown below,
ROD DIAMETER
HOUSING DIAMETER
1.75     '+.000
           '-.003
2.174
+.004
+.000
2.500   '+.000
           '-.004
3.116
+.005
+.000
5.000   '+.000
            '-.004
5.616
+.005
+.000
How can I merge cells using scripts. Please do guide me!
Revathi
Scripting
4.3K
Community Expert , Jun 06, 2017 Jun 06, 2017
There is a script from Indiscripts that is exactly for this purpose:
Indiscripts :: Improve the Way you Merge Cells in InDesign
The script works most of the time but I have noticed from time to time that despite selecting the cells and running the script, nothing happens, but if I select fewer cells, then the script works again. Bizarre.
Enthusiast ,
Bonjour,
Ceci peux vous guidez,
Ex :
var ligne04 = "Test: ";
if(app.documents.length != 0){
        if(app.selection.length != 0 && app.selection[0].constructor.name == 'Table'){
                var nomTableau = app.selection[0];
                        nomTableau.rows[0].cells.item(0).merge(nomTableau.rows[0].cells.item(1));
                        nomTableau.rows[0].cells[0].texts[0].insertionPoints[0].contents = ligne04;
                exit();
        else{
                    alert("Selection un tableau");
                    exit();
    else{
        alert("Ouvrait un document et Mettre son cuseur dans le points de départ");
        exit();
If the answer wasn't in my post, perhaps it might be on my blog at colecandoo!
Hi  Colin,
Thanks for your response.I have my cells as ,
1.750+.000-.003
2.500+.000-.004
5.000+.000-.004
Using the script I was able to merge my cells as ,
1.750
+.000 -.003
2.500
+.000 -.004
5.000
+.000 -.004
I tried to merge it as,
1.750
+.000
-.003
2.500
+.000
-.004
5.000
+.000
-.004
I tried to change the row values to columns but the merging of cells remain the same. Please do guide me.
Revathi
Jun 07, 2017 Jun 07, 2017
Hi Revathi,
if "the script" is the one written by Marc Autret—SmartCellMerge.js—you can change the separator to the one you like to see. I guess it'll be "End of Paragraph" {EOP} .
Or use any other sequence of characters.
Marc defined three that you can insert with buttons:
"Tabulator", "End of Paragraph" and "End of Line".
To get to that dialog where you can define this, run the script without selecting anything.
Marc Autret is describing this in detail.
http://www.indiscripts.com/blog/public/data/improve-the-way-you-merge-cells-in-indesign/_en_04.png
Uwe
Jun 08, 2017 Jun 08, 2017
Hi Uwe,
Thanks for your guidance.I got it.
Now I have cells as
ITEM_NO
ID
OD
Ht
GROOVE WIDTH
GROOVE WIDTH TOLERANCE 1
GROOVE WIDTH TOLERANCE 2
BRS-17502
1.750
2.174
0.166
0.166
+.010
+.000
BRS-25003
2.500
3.116
0.247
0.247
+.010
+.000
BRS-50003
5.000
5.616
0.247
0.247
+.010
+.000
I have to merge it as:
ITEM_NO
ID
OD
Ht
GROOVE WIDTH
BRS-17502
1.750
2.174
0.166
0.16      +.010
             +.000
BRS-25003
2.500
3.116
0.247
0.247    +.010
              +.000
BRS-50003
5.000
5.616
0.247
0.247    +.010
             +.000
How shall I get it?Please do guide.
Revathi V
Hi Revathi,
I guess you need a tab between 0.16 and the +.010 and a tab before +.000 as well.
That means you need an extra step before merging the value cells of GROOVE WIDTH and GROOVE WIDTH TOLERANCE.
You could select all value cells of GROOVE WIDTH and run a Find/Replace GREP on the selected cells:
Something like that:
Find:
Replace:
\t$0
And then do the merge of GROOVE WIDTH and GROOVE WIDTH TOLERANCE with no sepaparation character.
1. After GREP Find/Replace:
2. Changing preferences with Marc's SmartCellMerge script.
No separation character applied.
3. After the merge:
Uwe
Apr 05, 2018 Apr 05, 2018
Hey!
Sorry to resurrect this topic, but I am trying to use the script to merge Vertical, and when I try to merge the rows of column 10 with 11 it does not work.
Anybody has fixed this issue? - I guess it's some bug in the code but I can not find it...
Here are some tests.
For reference I am using a 21x3 col table and merging 2 rows.
C2-C21 - OK
C3-C21 - OK
C4-C21 - NO
C10-C21 - NO
C11-C21 - OK
Any JS masters around?
Marc's script does that to me from time to time. I find if I make a smaller selection, that will work, so it may mean running the script a couple of times.
Dirk becker also has a script that works as a startup script but serves a similar purpose: Scripts for InDesign Tables
Thanks Colin
