Hello,
I have an interesting situation that only seems to happen in Acrobat Pro 10 on Windows 7. I have replicated the issue in multiple users on the same machine and cannot explain the behavior besides to say that it's related to the "\AppData\Local\Adobe\Acrobat\10.0\UserCache.bin" file. When the "UserCache.bin" file is deleted and the PDF is double clicked in Windows Explorer it launches in Acrobat Pro X without issue. To close Acrobat Pro and double click the same PDF again Acrobat Pro launches but hangs immediately and does not respond. These PDFs that are exhibiting this problem are coming from an Ad agency's accounting software. I am able to launch the PDFs in Acrobat Reader on the same workstation without issue. I am not having any issues with these files in Acrobat 9 Pro on another computer. All other PDFs launch in Acrobat Pro 10 without issue.
Adobe Acrobat Pro X is up to date and has been uninstalled and reinstalled. The Windows User Profile has been recreated as it was thought that it was User specific.
I am at a loss as to how to continue troubleshooting.
Does it happen in currently supported versions?
No, this issue is not present with current versions from what I can tell. I installed a trial of Acrobat 11 Pro on my spare workstation and could not reproduce the issue with any of the files. On another note, I installed Acrobat 10 Pro on the same workstation (Win7) and replicated the hang / not responding issue with the files from the Ad agency.
According to the Ad agency, there are no non-standard fonts and the files should be compatible with Acrobat 9 and higher.
Sounds like a bug. You say X is "up to date" but what specific version do you run?
Adobe Pro X Version: 10.1.16.13
