Hi, I'm creating a form. I added a comment field to create a box around some fields. I saw that I was able to change this field.
(I allso added a stamp - [Confidential])
I clicked restrict editing and it promoted me to add a password, and I didn't want to do that and tough maybe I could just restrict without a password.
(I know that wold not be secure, but that doesn't matter much)
I closed the password windows, and the check box for restrict editing was cleared.
I alls
I clicked save, and the field changed to blue boxes (red for required)
A bit baffled I went to the edit section again, I saw the restrict editing was sett, and when I tried to remove that I prompted if I wanted to remove, clicked yes, and then I prompted me for the password! And it will not accept a blank password!.
(I thought I maybe, but not likely, that I entered some password. So I created a new form, did the same, and same problem)
It lookes like I can edit the for i Acrobat, but can't remove restrict editing. That may be OK in the end, but if that is not a god solution, I want to be able to change that.
Any ideas?
best regards, Kristian.
What version of Adobe Acrobat?
Hi, it's Acrobat Professional DC - 2017.009.20044
Can you share the file?
Hi, I can't find a "uplod file"-function.
In Acrobat DC use Send & Track.
Hi, I have been traveling so I wasn't able to test/do this before now. Here is the link:
/K
