Followed article Print with color management in Photoshop
And still unable to print from photoshop using Epson 760 Print on mac
Both using colour management or using the printer always comes out blank pages, the printer works fine with everything else
Does any one has a solution for this ?
Have you tried resetting the Photoshop Preferences?
Mohit
Hi robertj,
Please reset the Photoshop preferences ad check if that helps, refer: Preferences in Photoshop also, if you are using a wireless printer, please connect the usb and print.
Let us know if that helps.
Mohit
Hi there,
The printer is directly plugged in via usb.
Rob<Content edited by the Moderator>
www.jellycat.com
Mohit
That’s solved the problem, thanks.
Robert Jewiss
Jellycat Limited
<<Edited by the Moderator>>
www.jellycat.com
