Is there a way to replace everything inside the Quotes(The text inside this is not the actual text.) ? " / EVERYTHING BETWEEN THE SLASHES PLUS SLASHES /" or "/ Everything after the Last Slash" Such as if i have English, french and Spanish text and want to delete everything after French or to make it from
English / French / Spanish to:
English / Spanish
or
English / French
Your example can easily be accomplished using conditional text in InDesign. With conditional text you can make separate conditions for English, Spanish and French and then hide unhide them as needed.
I dont think there is a way within Indesign to use either grep or Find/change to replace language specific content.
While other professionals here suggest some better methods and techniques you can have a look at conditional text
https://indesignsecrets.com/finally-conditional-text.php/comment-page-1
...Copy link to clipboard
https://indesignsecrets.com/unexpected-conditional-text.php
-Aman
Thank you I'll Check this out now.
This might just do what i'm wanting. thank you.
