Ok, here is the problem:
os: WIndows 10, Tablet: Cintiq 27touch, works like a charm in other versions. BUT, on Photoshop cc 2017, the touch cease to work while Free Transform. I cant, pan, Zoom. I did some research, And it paears it have to do with surface tablets, Its a new feature:
Well, I have a Cintiq, not a surface, and that does not work. It only deactivate the touch capabilities.
Anyone has an answer? thanks you so much in advance.
Free transform is not a touch gesture. Also even if can use touch with Free transform active it would not effect the transform. the transform bounding bounding box would also zoom. You can easily see this using the zoom shortcuts with Free transform is active Ctrl++ and Ctrl+- so if free transform turns off touch support you can zoom with the shortcuts.
Please post how you have set up you OS, wacom and Photoshop devices configuration.
Well, is in spanish. But Basically, in touch, I have the preferences in "my movements" instead of windows movements, Of course I already try on windows movements, to see if it works. But nothing. I also download the try of photoshop cc 2018, on my wacom mobile, and same problem. Touch deactivates on free transform.
Photoshop supports touch gestures. Transform is not a gesture
Well, Im just saying, that Adobe claims than you can pinch, zoom and rotate, while in transform ( as in photoshop 2014)
From an article find in https://helpx.adobe.com/photoshop/using/touch-gestures.html
The thing is, I have photoshop 2017, and when I am very clore to the image, and want to free transform or scale, and want to zoom out to see to what level I want to scale the image, I simpli pich on my screen. But since photoshop 2015, I cant do that. The touch stop working. Even if I follow the instruccions abobe.
