I have a folder of tifs that were recovered from an sd card out of a Canon 7D. The only recovery software that worked saved them as Tif files. I can view the thumbnail but not the picture itself and the files cannot be opened by Photoshop CC or camera raw They all spit out a message to the tune of "unsupported tiff format" or
" Could not complete your request because the TIFF file uses an unsupported compression method."
Please help I have over 1000 pics stuck!!!!
This is the format of the files I have: CANKN_Cankn EKS 7@_28472-74877_000.TIF
Since the Cannon 7D writes CR2 RAW Files and jpeg Files the recovery software did not recover what the camera wrote of if it did it gave the recovered files the wrong extension. Try renaming the recovered files from *.tif to *.CR2 and *.jpg. Tri .jpg first since you had 1000 images on a SD Card. If some files are Large rename them *.CR2
Thanks JJMack but I have already tried this option and it did not work
Did you try opening the files in another application like Preview on a mac system on Microsoft Paint on a windows system?
Yes I tried to preview but all I can see is a thumbnail with no image
it sound like the files were not recovered....
Well, I do have the same number of files I had on the camera in the recovery file. It is the the first time that I encounter this issue in recovering files. Thank you for your help!
So you have a mac?
Maybe you can provide us with a sample file using Dropbox and we can try it in some different applications you might not have or see if the file is corrupted.
Dropbox - CANKN_Cankn EKS 7@_86072-240061_001.TIF
Hello R_Kelly hope you can help!
Unfortunately, it looks to me like the files are corrupted.
I actually got two applications to open the file, but just a green background was displayed and all the rest of the applications complained in way or another the file was unreadable.
Most likely the files were too badly degraded on the sd card to be recovered properly.
What happened to the sd card that the files needed recovery?
I don't know what happened. I was trying to transfer the photos to my hard drive through a card reader and it suddenly stopped and the card was displayed as blank...same with the second...Needless to say that I stopped the transfer with other cards
Thank you for your help!!
Edith
Hi R_Kelly,
I have tried with another recovery tool and this is a sample of the new files I got? I still can't open them but getting another message for the jpg file ( Could not complete your request because an invalid JPEG DQT quantizer value is found) I am so distress as most my pictures seem to be corrupted from my recent trip ti Thailand and Laos. Hope you can see something. I did nothing specific with the cards. I was uploading the photos from the card reader and it suddenly stopped and was displaying blank folder. I tried with the second card (same brand-Scandisk-) and the same thing occurred. All other cards from a different brand are fine
I've had this happen getting TIFF files from an HP Digital Sender and opening it with my Mac. I fixed my problem by opening the files in a Linux machine, opening it with Shotwell, and saving it as another TIFF. Alternatively, I have made this work too from the Terminal of the Mac with Imagemagick. (To install, Install from Binary Distribution @ ImageMagick . There is also a Windows version in that page.)
The command to use is convert.
Usage: convert [options ...] file [ [options ...] file ...] [options ...] file
It can determine what file type to save it as using the filename extension. For example, to change it to BMP format:
/opt/ImageMagick/bin/convert FileThatCannotBeOpened.tiff FileThatCanBeOpened.bmp
I have exactly the same problem... also with the picture turning green once I exported it to jpg online... did you use Disk Drill by any chance? Spending money on recovering the files but not having them recovered is the worst... I hope someone can help T.T
