Hello!
Following this video
to get myself acquainted with 3D capabilities of PsCC2017.
On the 56th second https://youtu.be/PS-S45Xt-NU?t=56 it shows that once the APPLE category gets selected the CC2017 immediately shows X-Y-Z widget.
In my case that does not happen.
Could someone please give me a hand here?
Hi
As I replied in the other threadas far as I remember there used to be a Shows - 3D Axis option but as I never switched that off, I don't know when it no longer appeared.
You could got to preferences Performance and try changing the drawing modes to see if it will appear (you will need to restart after changing)
In the meantime , even without that tool you can still rotate.
Either go to View - Show - 3D Mesh bounding box and tick it then rotate by grabbing the bounding box
or
With the object selecte
...Copy link to clipboard
Hi
or
With the object selected in the 3D panel - go to the properties panel - select Co-ordinates and enter the rotation directly
Dave
Thank you, Dave! It helps!
Funny thing 2017-06-11 22.28.tvs - Google Drive when trying rotating a 3D object I see those controls inside
