I had After Effects Cc 2015 installed in my laptop.I have NVidia GeForce 940MX 4GB graphic card installed in my laptop.This graphic card is not in the list of compatible graphic card for After Effects for fast 3D rendering.Is there any way I can use my graphic card for after effects ?
Yes it did after updating
Thanx
Would you browse the file of the path below and add your name of your graphic card manually? Please do not forget to reboot your After Effects after you edit the file.
C:\Program Files\Adobe\Adobe After Effects CC 2015.3\Support Files\raytracer_supported_cards.txt?
Hey
Still GPUSniffer is not recognizing my NvIdia graphic card.What should I do
Turn off the intel GPU in the BIOS.
Mylenium
How to turn off GPU in BIOS?
How to turn off GPU in BIOS for Windows 10
This video may help you to switch the graphic card.
Hey
I have done the same as mentioned above but still in GPU SNIFFER Intel graphic card is showing in Renderer
Can you find the Nvidia card from Preferences > Previews > GPU Information of After Effects? Still Intel only?
Yes I am able to find out my Nvidia graphic card in the above mentioned location
In Ray tracing :a)When CPU is selected ,OpenGL shows up my Nvidia card while CUDA is greyed out
b)When GPU is selected OpenGl and CUDA both shows up my Nvidia graphic card
1 question-I should select CPU or GPU in ray tracing?
2 question-Still in GPUSniffer,Intel graphic card is showing up in Renderer.Is it OK ?
1. You set GPU (ray tracing) on and choose your graphic card. You apply some GPU accelerated effects in After Effects and check how faster the effects works.
2. I am not sure about the details of the specification of Sniffer. I do not know how Sniffer chooses the cards and sets them as primary or secondary. It would be better to talk to Adobe tech support.
Something else you should know: ray tracing in AE is essentially dead. Adobe hasn't done a thing with it since they got C4D Lite, which renders a lot faster, anyways.
Hi ManojG,
Update After Effects. Does that help?
Kevin
Thanx
