I am creating a PDF form to help my partner and she wants the some of the fields to auto-tab / auto-focus when the active field is complete.
Is there a way of doing this? If so, any idea how I can? Never done anything like this so I am a complete amateur.
Alternatively, are their any specialists that I can commission to do it if it's above my level?
Thanks in advance for any help.
Tom
Add the function AutoTab as document-level function.
Put the call of the function as custom keystroke script in the form field.
Instead of using 8 fields you should use only one field using the Date format, it's more user-friendly.
Hi @JR_Boulay,
thanks for the input. It's not just on date format, there are a couple of fields that require it - where they need the single character format?
Cheers
Use the Comb option of the text field.
As suggested, create a single text field and then go to its Properties, and under the Options tab select these options:
Thanks try67​ – I'll look at that for the date format.
Is there a way of doing it with single digit entries in forms? As the form will require that too.
What do you mean?
On Mon, Jun 12, 2017 at 3:02 PM, TomRogersDesigns <forums_noreply@adobe.com>
Sorry – I meant there are other fields on the form similar to the date design that would require it to auto-tab / auto-focus to next field when complete.
So, basically if I didn't change the design of the form, is there still a way of doing it?
Thanks.
You can use the AutoTab function:
JavaScript for auto tab. Is there a way for me to format the fields to only accept numbers?
Thanks Bernd.
This looks great. One more, very dumb, question – but where / how do I add the javascript?
Sorry!
Hi
I am quite new and unable to find an autotab function
Thanks for any help
