Today I found a shared .xd file with toggle buttons at this link:: Toggle (Freebie Inside) by Joao Carvalho - Dribbble
I wonder if there is a method to create a little shadow at bottom side of the button like that topic because when I tried to create these toggle buttons, I cannot find out how to do it.
Sorry about my bad English. I really appreciate your helps. Thanks for reading
That's probably done with a really subtle gradient. Gradients are available in Mac, and will be very soon on Windows!
-Elaine
You can use the shadow property in the property inspector to get that effect. Hope that helps!
-Elaine
Thanks for your answer. By using the shadow property i just can create the shadow outside the button. What I see is there's a little bit darker at the bottom. Would you mind checking if that's correct or I am wrong? Thank you.
-Elaine
Oh I see! Thank you very much for your support ! Hope to see that soon!
