ps cc2017 create new file stuck on create dialog box
Jun 12, 2017 Jun 12, 2017
It's stuck when you create a new document.
CPU:I5-6500
Momery:16G
HARD DISK:128GSSD+1THD
SCREEN CARD:NIVIDA GF745
1.0K
Adobe
What happen if you navigate to the folder where the document is and you try to open it from the directory level? Have you moved the file? Can you try CMD or CTL N and see what happens? Are you getting an error message?
I  just want to create new psd file,it stuck one minute.
and then I create again,it's fine.
Adobe Employee ,
Does ESC dismiss the dialog? Can you go to Help> System Info... and copy the text contents in a reply?
@Celeste That is the New doc dialog and it is trying to create a new doc not open an existing one, just as an FYI. There may be a localization issue or a file permission problem??
thx,
steve
Yes - I am wondering if he can bypass the New Start Window temporarily if it is a localization issue, he can still get on with working on the task at hand.
Adobe Employee ,
Yes, you can try reverting back to the legacy New dialog and see how that works.
Create documents in Photoshop using templates and presets
thx,
steve
press ESC is no work.
You can see this issue when you first time create new PSD file  after start Photoshop.exe .
Can you try a different type of document?
Does it happen on creating any document?
I just create new psd file.
Are you signed in to your Creative cloud account?
Ii don't see your avatar in the upper right corner.
Jun 13, 2017 Jun 13, 2017
yes , I signed.
I found that this problem when  I  create new blank PSD file first time.
if i second time do it ,it's fine.
Adobe Employee ,
thx,
steve
Adobe Photoshop 版本: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
启动次数: 15
版本: 10 或更高版本
系统结构: Intel CPU 系列: 6,型号: 14,分级: 3 具有 MMX 扩展指令集,SSE 整数,SSE 浮点,SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
物理处理器数: 4
处理器速度: 3192 MHz
内建内存: 16325 MB
空闲内存:2 MB
Photoshop 可用的内存: 14437 MB
Photoshop 占用的内存: 72 %
历史记录缩览图: 启用。
Touch Bar: 启用。
别名图层: 停用。
修改键调板: 启用。
远光灯: 停用。
图像拼贴大小: 1024K
图像高速缓存级别: 4
字体预览: 中
文本书写器: 东亚
OpenCL 于 16:32:47 (Initializing OpenCL and OpenCL enabled features)
在 2017/6/13 上崩溃显示器: 1
显示边界: 上= 0、左= 0、下= 1080、右= 1920
OpenGL 绘图: 启用。
OpenGL 允许使用旧 GPU: 未检测到。
OpenGL 绘图模式: 高级
OpenGL 允许使用普通模式: True.
OpenGL 允许使用高级模式: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA GeForce GTX 745"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="22.21.13.8233"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GTX 745/PCIe/SSE2"
glgpu[0].GLRendererID=4994
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um,nvwgf2um"
glgpu[0].GLDriverDate="20170517000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=4096
clgpu[0].CLName="GeForce GTX 745"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="382.33"
clgpu[0].CLBandwidth=2.52382e+10
clgpu[0].CLCompute=242.734
GUIDBucket:
  bucket: 88
  test: ReduceUXFriction
应用程序文件夹: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
临时文件路径: C:\Users\qeegu003\AppData\Local\Temp\
Photoshop 暂存盘具有异步 I/O 已启用
暂存卷:
  启动,119.2G,66.4G 可用
必需的增效工具文件夹: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
主要增效工具文件夹: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
安装的组件:
  A3DLIBS.dll  A3DLIB Dynamic Link Library  9.2.0.112
  ACE.dll  ACE 2017/01/26-01:10:02  79.579975  79.579975
  AdbePM.dll  PatchMatch 2016/11/03:19:48:57  1.578146  1.578146
  AdobeLinguistic.dll  Adobe Linguisitc Library  10.0.0
  AdobeOwl.dll  Adobe Owl  5.2.11
  AdobePDFL.dll  PDFL 2016/08/10-16:53:20  79.195992  79.195992
  AdobePIP.dll  Adobe Product Improvement Program  7.4.1.60.45263
  AdobeSVGAGM.dll  AdobeSVGAGM  79.579975  79.579975
  AdobeXMP.dll  Adobe XMP Core 2016/09/14-01:09:01  79.159824  79.159824
  AdobeXMPFiles.dll  Adobe XMP Files 2016/09/14-01:09:01  79.159824  79.159824
  AdobeXMPScript.dll  Adobe XMP Script 2016/09/14-01:09:01  79.159824  79.159824
  adobe_caps.dll  Adobe CAPS  10,0,0,6
  AGM.dll  AGM 2017/01/26-01:10:02  79.579975  79.579975
  ahclient.dll    AdobeHelp Dynamic Link Library  2.2.0.1
  AIDE.dll  AIDE 2016/05/27-01:08:49  79.574279  79.574279
  amtlib.dll  AMTEmu  9.0.0.89BuildVersion: 9.0; BuildDate: Tue Aug 25 2015 7:30:38)
  ARE.dll  ARE 2017/01/26-01:10:02  79.579975  79.579975
  AXE8SharedExpat.dll  AXE8SharedExpat 2015/03/13-23:40:54  79.562390  79.562390
  AXEDOMCore.dll  AXEDOMCore 2015/03/13-23:40:54  79.562390  79.562390
  Bib.dll  BIB 2017/01/26-01:10:02  79.579975  79.579975
  BIBUtils.dll  BIBUtils 2017/01/26-01:10:02  79.579975  79.579975
  boost_date_time.dll  photoshopdva  10.0.0
  boost_signals.dll  photoshopdva  10.0.0
  boost_system.dll  photoshopdva  10.0.0
  boost_threads.dll  photoshopdva  10.0.0
  cg.dll  NVIDIA Cg Runtime  3.0.00007
  cgGL.dll  NVIDIA Cg Runtime  3.0.00007
  CITThreading.dll  Adobe CITThreading  2.1.0.1  2.1.0.1
  CoolType.dll  CoolType 2017/01/26-01:10:02  79.579975  79.579975
  dnssd.dll  Bonjour  3,0,0,2
  dvaaudiodevice.dll  photoshopdva  10.0.0
  dvacore.dll  photoshopdva  10.0.0
  dvacrashhandler.dll  Adobe Audition CC 2017  10.0.0
  dvamarshal.dll  photoshopdva  10.0.0
  dvamediatypes.dll  photoshopdva  10.0.0
  dvametadata.dll  photoshopdva  10.0.0
  dvametadataapi.dll  photoshopdva  10.0.0
  dvametadataui.dll  photoshopdva  10.0.0
  dvaplayer.dll  photoshopdva  10.0.0
  dvatransport.dll  photoshopdva  10.0.0
  dvaui.dll  photoshopdva  10.0.0
  dvaunittesting.dll  photoshopdva  10.0.0
  dynamiclink.dll  photoshopdva  10.0.0
  ExtendScript.dll  ExtendScript 2016/12/13-13:10:33  80.1089815  80.1089815
  icucnv40.dll  International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
  icudt40.dll  International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
  icuuc40.dll  International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
  igestep30.dll  IGES Reader  9.3.0.113
  imslib.dll  IMSLib DLL  10.0.0.11
  JP2KLib.dll  JP2KLib 2017/04/05-14:24:38  79.266006  79.266006
  libifcoremd.dll  Intel(r) Visual Fortran Compiler  10.0 (Update A)
  libiomp5md.dll  Intel(R) OpenMP* Runtime Library  5.0
  libmmd.dll  Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler  12.0
  LogSession.dll  LogSession  7.4.1.60.45263
  mediacoreif.dll  photoshopdva  10.0.0
  MPS.dll  MPS 2016/09/14-15:20:26  79.577269  79.577269
  pdfsettings.dll  Adobe PDFSettings  1.04
  Photoshop.dll  Adobe Photoshop CC 2017  18.1.1
  Plugin.dll  Adobe Photoshop CC 2017  18.1.1
  PlugPlugExternalObject.dll  Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)  7.0.0
  PlugPlugOwl.dll  Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)  7.0.0.67
  PSArt.dll  Adobe Photoshop CC 2017  18.1.1
  PSViews.dll  Adobe Photoshop CC 2017  18.1.1
  SCCore.dll  ScCore 2016/12/13-13:10:33  80.1089815  80.1089815
  SVGRE.dll  SVGRE  79.579975  79.579975
  svml_dispmd.dll  Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler  12.0
  tbb.dll  Intel(R) Threading Building Blocks for Windows  4, 4, 2016, 0412
  tbbmalloc.dll  Intel(R) Threading Building Blocks for Windows  4, 4, 2016, 0412
  TfFontMgr.dll  FontMgr  9.3.0.113
  TfKernel.dll  Kernel  9.3.0.113
  TFKGEOM.dll  Kernel Geom  9.3.0.113
  TFUGEOM.dll  Adobe, UGeom?  9.3.0.113
  updaternotifications.dll  Adobe Updater Notifications Library  10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)  10.0.0.1
  VulcanControl.dll  Vulcan Application Control Library  5.3.0.16
  VulcanMessage5.dll  Vulcan Message Library  5.3.0.16
  WRServices.dll  WRServices Thu Jan 07 2016 04:50:10  Build 0.21960  0.21960
  wu3d.dll  U3D Writer  9.3.0.113
Jun 14, 2017 Jun 14, 2017
Can you try R-click on the PS icon and select "run as administrator " from the properties menu and see if that works?
Jun 15, 2017 Jun 15, 2017
yes, I try it,but is no work.
