When I render through Adobe Media Encoder, it only creates less than one second
Jun 12, 2017 Jun 12, 2017
Hi!  I have recently made a 30 sec animated composition in After Effects.  I used photoshop canvases which were pretty large and it also has music.  When I sent it to Media Encoder (preset Facebook and also tried YouTube) it only creates less than one sec.
Has anyone else had this problem and discovered a solution?
[Moved from the non-technical LOUNGE Forum to the Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Also edited the subject line for brevity - moderator]
187
In your Comp Timeline, where is the Work Area End located?
Most likely, you've accidentally set the Work Area to about one second.
If this is the case and you want to render the entire Comp, double-click between the Work Area Start and Work Area End to reset to the length of the Comp and then send it to Media Encoder again.
-Warren
Adobe Employee ,
Jul 26, 2017 Jul 26, 2017
Hi ChristineB,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
