I can't open existing files in Photoshop. I've tried opening many different files of various types (including .jpgs and .tiffs) the File Menu, going through Lightroom (which works fine), through Bridge, double-clicking files through Explorer, dragging and dropping, using "Recent Files". I don't get any error messages; Photoshop simply doesn't open a new window.
I can create a new file, which creates a new window.
The only error I can find is in the Windows Event log:
Faulting application name: Photoshop.exe, version: 18.0.0.53, time stamp: 0x57fde9fd
Faulting module name: Spaces.8li_unloaded, version: 0.0.0.0, time stamp: 0x57fde3d0
Exception code: 0xc0000005
Fault offset: 0x000007fed33f53d0
Faulting process id: 0x272c
Faulting application start time: 0x01d2e3fb33db7081
Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
Faulting module path: Spaces.8li
Report Id: 1235bf5a-4ff0-11e7-85c6-0071cc7ebe82
I tried uninstalling and re-installing Photoshop, and then the entire CC photography suite. I've got plenty of memory and plenty of disk space.
Adobe Photoshop Version: 2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006 x64
Number of Launches: 39
Version: 7 SP1
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3591 MHz
Built-in memory: 16301 MB
Free memory: 8026 MB
Memory available to Photoshop: 14507 MB
Memory used by Photoshop: 60 %
Any help would be appreciated.
Hi kingfysher,
When you open any file Photoshop what you do you see, any error code or may be a black screen? please share the screenshot for the same.
Also, you may try and reset the Photoshop preferences and check if that helps.
Mohit
Thanks Mohit
This is what I get when I try to load an image (whether by starting PS first, choosing "Open with ->Photoshop" from Windows Explorer, or via Lightroom or Bridge). Note that it's simply the Photoshop app without any files open.
No error message is displayed by Photoshop itself. and nothing gets created in C:\Local\Temp\PhotoshopCrashes when I try to open a file.
I've tried to change the performance and file handling preferences, but it hasn't made any difference.
