Script to Set Default PDF Presets
Jun 12, 2017 Jun 12, 2017
Hi guys -
I've been looking around for awhile for something that would help increase our workflow's efficiency. We have a certain setting we save all of our PDFs in [Color Press], but I can't figure out to set that as the default preset. Every time we Save As PDF, we have to change the PDF setting to [Color Press] manually.
Is there a way to do so in AI or a script that will Save an open file to a preset instead of the [Illustrator Default]? We would ideally still need the option to choose where to save the PDF, as not all of our PDFs get saved into the same folder as the AI file.
Thanks in advance!
Scripting
4.1K
Participant , Jun 13, 2017 Jun 13, 2017
This should help :
var main = function() {
var doc;
if ( !app.documents.length ) {
return;
doc = app.activeDocument;
var psts = app.PDFPresetsList;
var n = psts.length;
var found = false;
var presetName = "LUDILABEL",
f;
while ( n-- ) {
if ( psts==presetName) {
found = true;
break
if ( !found ) {
alert("Unable to find pdf preset "+presetName );
return;
var opts = new PDFSaveOptions();
opts.pDFPreset = presetName;
f= File.saveDialog ("Where di you want to save the file ?");
if ( !f ) return;
doc.saveAs ( f, opts
Adobe
Participant ,
This should help :
var doc;
return;
var found = false;
f;
while ( n-- ) {
found = true;
break
if ( !found ) {
return;
if ( !f ) return;
doc.saveAs ( f, opts );
main()
Loic
Ozalto | Productivity Oriented - Loïc Aigon
Thank you so much Loic! This seems to be what we were looking for. 2 quick questions for you -
1) Is there a way to keep the filename when saving without having to retype it? When I run this script I have to rename the file (it's blank)
2) Can the default location to save open up where the AI file is located? Right now it opens up to save in the most recently saved location.
Thank you again, and sorry for the flurry of questions!
Participant ,
var doc;
return;
var found = false;
var presetName = "SOME_PRESET_NAME",
f;
while ( n-- ) {
found = true;
break ;
if ( !found ) {
return;
f = File ( doc.name );
f= f.saveDlg ("Where do you want to save the file ?");
if ( !f ) return;
main();
Here it is…
Thank you again. I was actually in the middle of editing my second question as I was able to dig a little deeper and found that
f= Folder(app.activeDocument.path).saveDlg("Choose PDF output folder:");
would keep the file location the same as the original folder which is exactly what I needed for location.
Thank you for your time and wisdom! Still learning, slowly but surely.
Participant ,
Apr 21, 2022 Apr 21, 2022
Is there a way to adjust this script to have it just open a dialog box for my PDF presets so I can choose each time which I want to use?  Thanks in advance if someone could tweek this script!
Participant ,
I just realized that what I'm actually asking for is to adjust the existing SaveDocsAsPDF script to do what I'm asking above.  Want it to be a batch "Save as" function.
Not sure if it's still relevant in this thread, if not please move to wherever or tell me where to move it.  Thanks!
Participant ,
Apr 22, 2022 Apr 22, 2022
I made a new post called, "Modified Illustrator Script Needed for SaveDocsAsPDF" to address my request.  Please respond to that if anyone happens to see my previous comments on this thread, thanks!
Participant ,
In fact it's even needless. If you need to save it to the exact location of the active document and given it's saved already, you could save directly with
doc.saveAs ( File ( app.activeDocument.fullName.replace ( /\.ait?$/i, "")+".pdf" ) );
hence avoiding the need of a dialog.
Jun 14, 2017 Jun 14, 2017
That makes sense, we do occasionally need to save it in another folder as well so it's nice to have both options.
From what I've read, hotkeying a script to an action (Insert Menu Item) will reset every time Illustrator is restarted. There's no known workaround for this yet correct?
Thank you again!
Sep 27, 2017 Sep 27, 2017
Hi
Can you please explain me what I am missing? Thanks
function main(){
    var doc =app.activeDocument;
    doc.saveAs ( File ( doc.fullName.replace ( /\.ait?$/i, "")+".pdf" ) );
"doc.fullName.replace is not a function"
Jan 27, 2022 Jan 27, 2022
I know this is an ancient thread but I'm sure others will continue coming across this for years to come.
Searching for answers as to why the error
[...].replace is not a function
was thrown lead me here.  Is it possible the value in doc.fullName might be a number?
Per https://stackoverflow.com/questions/18862400/replace-is-not-a-function, replace is only a function of a String object; if the value might at any time be considered anything other than a string, encasing it as a String object should force the value to be interpreted as a string and therefore grant access to the String object's functions:
doc.saveAs ( File ( String(doc.fullName).replace ( /\.ait?$/i, "")+".pdf" ) );
Let us know if you find out otherwise.
