I am looking at the 'Export Layers To Files.jsx' to convert the parts of the exportChildren to C++ for my plugin, I need to know does .duplicate() duplicate a Element to a new document (does it copy the element, create a new doc, and paste it)?
function exportChildren(dupObj, orgObj, exportInfo, dupDocRef, fileNamePrefix) {
for( var i = 0; i < dupObj.artLayers.length; i++) {
if (exportInfo.visibleOnly) { // visible layer only
if (!orgObj.artLayers.visible) {
continue;
dupObj.artLayers.visible = true;
var layerName = dupObj.artLayers.name; // store layer name before change doc
var duppedDocumentTmp = dupDocRef.duplicate();
if ((psdIndex == exportInfo.fileType)||(png24Index == exportInfo.fileType)||(png8Index == exportInfo.fileType)) { // PSD: Keep transparency
removeAllInvisible(duppedDocumentTmp);
Perhaps! In that script it would depend on what "dupDocRef" is. There are many duplicate methods in Adobe Photoshop's Scripting DOM.
...Method Paramaters Parameter type Returns What it does
duplicate([relativeObject][, insertionLocation]) ArtLayer|LayerSet,ElementPlacement ArtLayer|LayerSet Creates a duplicate of the object .
duplicate([targetDocument]) Document Channel Duplicates t
duplicate([targetDocument]) Document Channel Duplicates the channel.
duplicate([name ][, mergeLayersOnly]) string,boolean Document Creates a duplicate of the document object.
duplicate([relativeObject][, insertionLocation]) ArtLayer|LayerSet,ElementPlacement LayerSet Creates a duplicate of the object.
duplicate(name) string Duplicates pathItem object with the new name.
Look like it is method 4 the way it is coded so yes it creates a new document in Photoshop and returns the document object in the variable duppedDocumentTmp
It look line method 4 because of the variable name used by the coder implies a document object is expected to be returned.
Then all the invisible layer in the duplicated document are then removed by the script in this new document.
